Results 1 to 3 of 3
Thread: Procon Series 3 in espresso machine
    Oct 2009
    5
    My procon pump was leaking, so I quickly ordered the wrong one... Series 3 stainless steel 125psi with 3/8 inlets.
    I havent installed it yet, but I assume with half the normal pump pressure I will only get half the pressure out of the group head?
    Running Boema 2 group.
    Dan
    Jun 2008
    1,520
    Re: Procon Series 3 in espresso machine
    contact your supplier before installing they may swap you for the right one +- a few $$? if it is a site sponsor it might help :)
    but if your running on mains pressure at 3 bar you should get the 130 psi you need for 9 bar if they will no return it
    good luck, dont forget the pictures :)
    Oct 2009
    5
    Thanks Maheel. Ordered from US so no returns poss... Fortunately only $70 delivered (Yay the exchange rate)
    Maybe Ill flog it off and order another, unless there is someone here who can do a rebuild on the original.
    Or try it and see...
  1. Quaha Nepoletana series 2 combi machine
    By mattwatt in forum SOLD
    Last Post: 23rd June 2012, 08:53 AM
  2. Extraction Question (Sunbeam Cafe Series Machine)
    By jessicadixon in forum General Coffee Related...
    Last Post: 14th May 2011, 01:48 PM
  3. KitchenAid Pro Series Espresso Maker
    By pszilard in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 11th April 2007, 02:27 AM
  4. [m]: Re: KitchenAid Pro Series Espresso Maker
    By Dimal in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 28th March 2007, 11:16 AM
