Results 1 to 6 of 6
Thread: Brasilia Cappuccino - water flow too slow
    VB
    VB is offline
    Nov 2009
    4
    Hi,
    My Brasilia Cappuccino (1998) used to produce a perfect shot with extraction time 25-30 sec.
    As of few weeks, the flow of water from the group head has considerably slowed down - it takes 45 sec for 30ml WITHOUT the portafilter in the group head.
    The pressure from the steam nozzle is fine and the flow of water through the hot water pipe is fine as well.
    Any suggestions where I should be looking?
    VB
    Jan 2008
    1,756
    Re: Brasilia Cappuccino - water flow too slow
    I would say scale and or coffee oils, whats your cleaning regime? eg chemical/water backflushing, descaling etc has it ever been serviced?
    cheers
    warren
    VB
    VB is offline
    Nov 2009
    4
    Hi Warren,
    I backflush my machine with chemicals once a week.
    Not sure on the descaling as I got it used, but have not descaled it in the last 6 months since Ive had it.
    VB
    May 2008
    600
    Not sure what you have done, b ut I would take off shower screen and dispersion block and clean these off. Backflush again. if that doesnt do it check if you group has some sort of jet/flow restrictor in there and descale this. If that doesnt do it, it check that there is no significant scale in pipes/fittings from pump to group. and if that doesnt do it I would check pump operation.
    VB
    VB is offline
    Nov 2009
    4
    Thanks for the replies,
    Yes, I cleaned the shower screen and the dispensation block.
    I havent descaled yet, so Ill give that a try and see if that helps.
    VB
    VB
    VB is offline
    Nov 2009
    4
    Yes, I got the descaler today and it did the job.
    The machine is back to normal information.
    VB
  1. Brasilia Portofino Del 2 from 2008 - water flow problem?
    By calskinator in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 19th June 2013, 05:05 PM
  2. slow water flow
    By skywalker in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 27th May 2011, 08:31 PM
  3. Replies: 0
    Last Post: 15th November 2009, 12:23 AM
  4. Whats with the slow flow of my EM6910?
    By sampam in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 16th July 2009, 05:45 PM
