Results 1 to 12 of 12
Thread: Bezzera Galatea Domus--- Crema issue.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,885
    Ive owned the BGD for a month now and am not 100% happy with the amount of crema its producing or should I say not producing, its ok, but not outstanding, believe it or not was getting a better result from the old Silvia.
    Am wondering what the thoughts are of other BGD owners? are you using the supplied double basket or have you changed to something else?
    Im not new to this game, have owned espresso machines for over 10 years and understand the relationship between bean quality, freshness, grind, tamp, basket size, temperature etc.
    Thoughts please. :-/
    May 2008
    441
    Re: Bezzera Galatea Domus--- Crema issue.
    Hmm, my first thought was "are you using fresh beans, ground on demand, and tamping properly?" but you seem to have those covered!
    I havent used this machine but I can guarantee that its capable of producing great espresso (with great crema) simply based on the fact that lots of CSers own them, and lots of sponsors sell them.
    Is your machine clean? Does it get a chemical backflush a few times a month?
    Do you flush before each shot? If youre not, this could be burning the coffee and killing the crema. Just flush a little water through the grouphead before each shot (to get rid of the super-heated water from the HX) until it stops spitting.
    Is it running hot? To answer this, when youve left the machine for 10 minutes or so and then flush water through the group head, how long do you need to do so before it stops spitting? If you need to flush more than, say, 100mL (others might have a better estimate there...) then your machine could be set to too high a temperature.
    How do your shots taste? How do they look when they are extracting? If they taste burnt, or bitter, or sour, or thin and watery... or if they are gushing, blonding early, or running very thin - this could give us some idea of whats wrong.
    Have you tried different sources of fresh beans? Some may produce more crema on your machine than others.
    Hope something of that is helpful.
    Stuart.
    Jun 2009
    Moonta SA.
    6,885
    Quote Originally Posted by 6C6B6A7E6D6B786D7E716B1F0 link=1259654151/1#1 date=1259658627
    You may be onto something here Stuart, must admit flushing before shots is something I dont do, will crank her up now and give it a try.
    Will report back soon.
    Jon.
    Apr 2008
    Brisbane
    5,113
    In addition to a cooling flush as described above & keeping your machine internals clean with regular back-flushing
    Correct dosing is important and the correct tamped puck depth for a Bezzera Galatea is 8mm
    Jun 2009
    Moonta SA.
    6,885
    Quote Originally Posted by 46626B6B68685246627E60620D0 link=1259654151/3#3 date=1259666298
    Evening KK, 8mm eh? how did you come up with this? is that 8mm puck depth or 8mm from top of basket to tamped coffee level?
    Cleaning not an issue, back flush daily and machine only month old.
    Thanks for the input.
    Jon.
    Apr 2008
    Brisbane
    5,113
    Quote Originally Posted by 023E372F3A5B0 link=1259654151/4#4 date=1259666927
    I own the same machine * ;)
    The way to measure from scratch the correct depth level is by trial and error
    This is done by locking in the group handle repeatedly until the puck is under by only a hairs whisker from the water screen in the group head
    Use that depth as future reference
    Some people use a 5 cent piece to help with this by viewing the indentation it leaves on the puck
    Ohh & its 8mm from top of basket to tamped coffee level
    Jun 2009
    Moonta SA.
    6,885
    Hmmmm, looks like cooling flush may well have been the answer, just pulled a shot for the better half (used cooling flush) and the crema was superb ;D
    About to pull one for myself, see if I can duplicate the success, stay tuned. :)
    Oct 2009
    76
    Hey Jon,
    I was happy to go with the advice of Jack from Bazari who suggested factory setup did not need to be adjusted. The flip side of that is the cooling flush is a critical step before pulling my first shot of the session.
    FYI: Im using the supplied double basket; probably still trying to perfect my dose/tamp method; beans are fresh & ground on demand and the crema results are good.
    Apr 2008
    Brisbane
    5,113
    I do a cooling flush with the double group handle locked into place & empty of any coffee
    Flush until the water runs as if its a perfect coffee pour and stop
    Them I grind, dose, tamp, load and extract a delicious espresso mmmmm
    Jun 2009
    Moonta SA.
    6,885
    Bingo, another great shot, will remember cooling flush from now on. Thanks for the input guys. ;D
    Jun 2007
    723
    Ive got mine running so it doesnt need a cooling flush - completely temp stable (well, <first crack through the shot) and lovely crema - often 4s & 5s on WBC scale.
    This was after an hours tinkering with Renzo from Di Bartoli.
    Jul 2008
    29
    And how is that? Did you install a PID temp controller?
  1. Bezzera Domus Galatea
    By Mark1812 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 18th June 2012, 09:28 PM
  2. New Bezzera Galatea Domus
    By Yelta in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 7th November 2009, 07:01 PM
  3. Bezzera Domus Galatea
    By paulie338 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 17th September 2008, 05:31 PM
  4. Bezzera Domus Galatea
    By hotdog in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 4th June 2007, 07:57 PM
