Results 1 to 6 of 6
Thread: HX Boiler Pressure verses Group Water temperature
    Dec 2006
    Perth WA
    572
    I have a Giotto Premium (Rocket)
    I am now trying to fine tune my shot as much as possible while I consider a quantum grinder leap.
    I have read that ideally the boiler pressure should be between 1.1 and 1.2 bars. *This should give the group water temperature at the group of about 92 *(I have lost the thread on this subject)
    As present my Boiler pressure is around 1.3 bars *The comment I read was that the shot would probably be thin and bitter.
    I cant quite define my shot taste but it sort of tastes ?sour? at the back of my mouth on the sides as an after taste. (Oh dear!)
    I would really like to improve my shot
    I would be very grateful for more/any information.
    I have changed the boiler pressure so I know how to do this. *
    I am using 5 Senses 24/7 - fresh beans through my Rocky the clumps of which I break up. *I get no blonding now. *The pour is a little on the slow side - like cold honey.
    Dec 2006
    Perth WA
    572
    Re: HX Boiler Pressure verses Group Water temperature
    A reply to myself:
    The general information about pressure and temp would be very useful.
    However I went to our local coffee shop who have a similar grinder to the one we are hoping for and had them grind some 5 Senses beans.
    Rushed home with my treasures and made my espresso -----
    It was good. *So I am thinking as every coffee snob of any experience keeps saying *to us novices --- the key to good coffee is the grinder.
    So I will leave Giotto boiler alone, enjoy my coffee which is okay and work towards the grinder of our choice.
    Thanks all
    David
    Feb 2006
    2,334
    Sell the rocky, sell the silvia, sell 1 tamper and youll have enough for a very decent grinder!
    kbc
    kbc is offline
    Apr 2008
    2,960
    My Giotto ranges from about 1.2-1.3 bar. There seems to be little difference in my shots throughout the range - All good.
    Try another coffee or upgrade your grinder. My k3 does a great job.
    Jul 2007
    2,288
    In general the Rocky is quite a capable grinder, although it is not in the upper tiers of grinders.
    I found my Rocky improved significantly when I applied the plumbers tape for stability and the did the stepless mod. Of course that still didnt stop me upgrading to a Macap M4D. :D
    There are also lots of technique issues that can cause "off" shots. The video of the VBM machine use is a very helpful resource (a search should find a link to it).
    Feb 2010
    2
    Thanks for the heads up Chris :)
  1. BZ40 - group head pressure not stable when adding water pressure limiter
    By pup26 in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 19th March 2012, 08:24 PM
  2. Using hot water in water tank for improved temperature stability?
    By jsrenaud in forum Brewing Equipment (non-machine specific)
    Last Post: 4th July 2011, 03:16 PM
  3. Boiler pressure - small high pressure boilers
    By dane5431 in forum General Coffee Related...
    Last Post: 6th May 2011, 04:16 PM
  4. Boiler pressure as water temperature
    By Andy-Gadget in forum Brewing Equipment (non-machine specific)
    Last Post: 18th March 2010, 05:47 PM
