Results 1 to 3 of 3
Thread: LaCimbali JR D help??
    blunt
    I searched but didnt find my problem Ive had this machine for 10 years and rebuilt it once. Its awesome but lately Im experiencing a problem at start up. It turns on fine and gets hot and the pressure gauge bulds up to where it should be but theres no pressure to speak of.. . as soon as i open the steam wand valve it purges a bit of steam and the gauge immediately drops to zero and i can then hear the heating element and pressure starts to build. In about 5 minutes all is well and it continues to work well . the key clues here are no pressure until i open the steam wand. Its almost like an air lock or air bubble in the system. Its getting progressively worse with time. it used to only do it once a month. any ideas that might help me troubleshoot this?? thanks guys
    Jun 2008
    1,520
    Re: LaCimbali JR D help??
    your anti vac valve is sticking, you can open the top and press it back in but they only cost aout +- $12 to replace and yo might find it now will stick a lot, maybe take it out and descale / clean it, but i reckon the oring in it might be old @ 10 years.
    goggle "anti vac" it *should look like this, maybe next to the pressure relief valve
    I call the problem "false pressure" on my machine i turn it on an leave the steam wand open in the morning. When i hear *it gurgling and a bit of steam i just shut the steam off then i hear the sari go "click" and its happy days :) maybe i should spend the $12... I had a laugh i am cheap
    leeham
    PS I am assuming your machine has one of these, but i reckon it will.....
    A_M
    A_M is offline
    Mar 2006
    6,381
    Leeham
    I recon ya 100% on the money I had a laugh.
    Ps. Spend the 12 :-)
  1. Yet another request for a LaCimbali M28 Manual (sorry)
    By morrisoc in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 10th November 2011, 06:09 PM
  2. LaCimbali not building up pressure
    By Snoop in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 13th August 2010, 10:53 AM
  3. FYI - LaCimbali Domus group seal - $0.50 locally
    By coffeegeek in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 16th December 2009, 03:00 PM
  4. LaCimbali M28 machines
    By JLJ in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 9th May 2008, 02:50 AM
