Results 1 to 9 of 9
Thread: need help - Giotto Premium. Strange sound.
    Jul 2004
    66
    Hi all.
    I have been using GP for the last 3m and the experience has been ;).
    So it was time for some cleaning and polishing.
    Usual weekly backflushing and descaled with citric acid over the weekend. Then,,, :(
    Whenever I start pour there is very fainty Joooo Wooook ( mild higher pitch at the end for about 1-2 second just before the pour starts.
    I do not think there was that sound before.
    The pour is OK. Taste OK. Milk fine. But the sound >:(.
    Any thoughts?
    Jon
    14,665
    Re: need help - Giotto Premium. Strange sound.
    Hello CL,
    This is what they call the 9 bar woofle...
    Worry not, its a good sign that all is well and is common in many e-61 mahcines.
    2mcm
    Jul 2004
    66
    You made my day, 2mcm. ;D
    I was a little concerned.
    Well another issue is that 14g general rule.
    I think I put about 16-17g each time make decent shots. ( of course it varied with different beans ) I tried 14g through K3 elite and Giotto P the shot was less than 20 sec and sour as well.
    Maybe I am doing something wrong? ::)
    My previous Silvia and Rocky combination required about 15g each time.
    Jon
    14,665
    Quote Originally Posted by 000205063C0F0C150611630 link=1268342485/2#2 date=1268355703
    Hi CL
    Just goes to shw that a Giotto is not a Silvia hey? I typically use circa 18.5g per Giotto double....My Faema is more like 20g...
    If it tastes good, youre on the right track ;)
    Feb 2006
    2,334
    Every machine, every basket and every coffee will require a different dose and grind setting to optimise flavour.
    Jul 2004
    66
    I feel better after talking to you GREATs.
    After all I was not doing something silly.
    Jon
    Feb 2008
    1,339
    Hey Jon
    Just a friendly word of advice...dont use citric acid to descale your machine. *It certainly releases scale but doesnt necessarily dissolve it, which means you run the risk of those flakes, blocking up some part of the machine.
    Far better to use a product specifically designed for coffee machines that dissolve the scale, like Bomboras Triple Action Descaler. *I think youll find that most sponsors have it on their shelves.
    Cheers!
    14,665
    Quote Originally Posted by 594F4A4A5B59555C5C5F5F3A0 link=1268342485/6#6 date=1268372419
    Hey Jon
    Cheers!
    Second that....I think Andy needs to set an auto replacement for the term citric acid with the name of one of the proprietory descalers.
    Were happy to clean up the results, at our special (why did you attempt to do that yourself using rubbish you read on the net) hourly rate...
    I have seen 3 or 4 botched citric acid descales so far ::)
    Jul 2004
    66
    Well again, I ll make sure to use proper one next time.
    J
  1. ECM Giotto - Repeated Clicking Sound - no coffee
    By dbernard in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 28th May 2011, 10:05 AM
  2. Your premium sound system
    By sidewayss in forum Off Topic
    Last Post: 15th January 2011, 03:15 PM
  3. question - Giotto PP or giotto premium?
    By cafe_lover in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 30th January 2010, 12:16 PM
  4. Differnce between Giotto Premium and Premium plus
    By patto21 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 1st February 2009, 07:59 PM
