Results 1 to 2 of 2
Thread: Rancilio s27 - boiling water line seems blocked
    Sep 2005
    146
    Hi All,
    I recently picked up an s27 off evilbay. The good news is that everything seems in relatively good working order except ....
    Hot water tap on this machine is volumetric, with the main board controlling a solenoid.
    The amount of water getting through the line is much lower than on my s26 which is operated by a manual valve. That is, the volume/minute is lower .... much lower.
    Is it likely to be a blockage in/at the solenoid? It looks pretty easy to remove the solenoid ie. let boiler cool, remove electrical connectors, then undo nuts on either side. What then?
    The other issue is the procon pump - which works, but seems noiser than my s26. I think it is on the way out. Is there anything I can do from a maintenance point of view?
    Tim
    Sep 2005
    146
    Re: Rancilio s27 - boiling water line seems blocked
    Quote Originally Posted by 2F342C3E6B6D6B625B0 link=1271508137/0#0 date=1271508137
    It was, pulled it apart, cleared it out, and while still not as fast as the s26, it much better than before. The difference could now be as a result of design? The hole in the solenoid for the water to pass through is quite small - not sure if there is a different level of restriction with the manual valve. Im not pulling it apart to see. Tim
  1. cleaning water tank and water carrying tubes of Rancilio Silvia from "gunk" ?
    By acid_rider in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 21st September 2012, 10:24 PM
  2. In-line resin water filters
    By gpieris in forum Brewing Equipment (non-machine specific)
    Last Post: 5th December 2011, 12:09 PM
  3. soy milk boiling temp
    By jilly65 in forum Milk Froth and Bubbles
    Last Post: 20th August 2009, 06:52 PM
  4. Boiling & filtering water for drinking
    By afton in forum Off Topic
    Last Post: 22nd July 2008, 02:00 PM
