Results 1 to 15 of 15
Thread: AAAAAGGGGGHHHHH My Bezera (BZ70S) wont fire up. Life is over.
    Jul 2009
    153
    HELP HELP HELP
    Just went to turn on the coffee machine, draws water but wont heat up or show any pressure on the gauge. :-/
    Used it yesterday no problems at all, backflushed it all as normal.
    Is life over ? :(
    Any suggestions from some of you gurus out there ?
    Does this mean I can justify ordering my Speedster ? ;D
    Thanks all
    Chester
    May 2008
    600
    Re: AAAAAGGGGGHHHHH My Bezera (BZ70S) wont fire up. Life is over.
    I dont know your machine, but in general if you have a multimeter id check the element and the pressurestat first.
    Jul 2007
    2,288
    Just order the Speedster. Dont check anything--you might find a cheap cure. ;D
    Apr 2008
    Brisbane
    5,113
    Turn on machine
    Open the steam nozzle (and leave open) as it may be an air lock
    Leave on until you hear a hissing sound [up to 30 seconds] then close the steam off
    If that does not fix it it will be one of 2 things
    1] Pressure switch
    2] Heating element
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 003522201028352A262B23470 link=1276079923/2#2 date=1276085567
    KISS... I like it :
    And then if ya desperate
    Try the following
    Quote Originally Posted by 0C2821212222180C28342A28470 link=1276079923/3#3 date=1276138086
    Turn on machine
    1] Pressure switch
    2] Heating element
    Jul 2009
    153
    Thanks for the advice, alas she still doesnt offer me coffee.
    Luckily I found my receipt and still have a month of waranty left ;D
    so off to the shop she goes.
    Sadly, Amanda thinks this is a better idea than ordering the speedster. :(
    HHHMMMM How do you blow up a coffee machine ? ;)
    14,665
    Its not impossible that you have tripped the thermal cutout on the boiler :-?
    More likely than not though, an element. Its possible/probable that you may find it not covered by warranty though as most manufacturer warranties exclude elements.
    Good luck
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 6D322A3C373C3039393A3A323E315F0 link=1276079923/6#6 date=1276172144
    Its not impossible that you have tripped the thermal cutout on the boiler *
    More likely than not though, an element. *Its possible/probable that you may find it not covered by warranty though as most manufacturer warranties exclude elements.
    All true...
    AND
    Quote Originally Posted by 3C302C32363C003C302A2F333A6D6D5F0 link=1276079923/5#5 date=1276171161
    HHHMMMM * How do you blow up a coffee machine ? *
    Much easer than many might thing and plenty of different ways to do it..
    First thing to remember... 98% of teh faults are all USER induced.
    Mar 2009
    37
    Bezzera coffee machine have the pretty look but their coffee shot is to quick. under 20 seconds. My advice is "Change it as soon as you can"
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 646E6668737268070 link=1276079923/8#8 date=1276485518
    Suggest USER rather than Machine.. Try fresh beans and the right Grind and tamp..
    Ron
    Ron is offline
    Nov 2005
    76
    Had a similiar problem recently with my Isomac Tea - turned out to be the electronic control box and I had to replace it.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,051
    Quote Originally Posted by 2329212F34352F400 link=1276079923/8#8 date=1276485518
    Please elaborate. :-?
    14,665
    Re: AAAAAGGGGGHHHHH My Bezzera (BZ70S) wont fire up. Life is over.
    Quote Originally Posted by 7B7179776C6D77180 link=1276079923/8#8 date=1276485518
    Sorry ciatuo but I disagree completely...
    If your experience with Bezzera is too fast in the shot department, you have one or more of the following issues:
    • underdose
    • incorrect grind
    • poor technique- incorrect grind and/or tamp. Adjust the nut on the group handle...
    • stale coffee
    • inadequate grinder
    A bad tradie always blames his tools ;) ::)
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 3339313F24253F500 link=1276079923/8#8 date=1276485518
    This and a few others sounds more like a quick post or 3 before a post in teh FS section..
    Jun 2009
    Moonta SA.
    7,051
    Quote Originally Posted by 745B52504778545B54525058505B41350 link=1276079923/13#13 date=1276493561
    This and a few others sounds more like a *quick post or 3 before a post in teh FS section..
    Looks like ya picked it in one AM. ;)
  1. Bezera BZ35 DE
    By Leo_Zdunkiewicz in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 26th November 2012, 05:37 PM
  2. FIRE FIRE FIRE in my Behmor 1600
    By mirx in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 26th May 2011, 11:01 PM
  3. Help with Rocky grind for Bezera BZ02
    By fender22 in forum Grinders
    Last Post: 15th July 2010, 05:44 PM
  4. Synesso basket for Bezera Galatea.
    By Yelta in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 20th January 2010, 09:36 PM
