Results 1 to 6 of 6
Thread: Water Tank probe
    Apr 2007
    399
    Water Tank probe
    I have noticed with my ECM giotto premium, that i need to clean the probe for the freshwater tank more often.
    For the first 4 years i never had to bother with it. Over the last 2 years ive been cleaning it at least once every 6 months or so. Sometimes even sooner.
    Basically its the same routine. Go to pull a shot, starts pumping, then stops withing a couple of seconds. Lift water tank and re sit it, starts again for a little then stops again.
    Pull it apart clean it all and all is good for a few months.
    The all over again
    So, do i just replace it or is there something else i need to be looking at?
    I clean it by rubbing it on a bit of sand paper. I do the same with the probe and the part that sits on the bottom of the water tank.
    14,665
    Re: Water Tank probe
    Quote Originally Posted by 042126200F4E0 link=1277789942/0#0 date=1277789942
    The all over again
    I doubt its the probe John (even though its a good thing to clean it),
    More likely, your water is low in dissolved solids (filtration?) and conducts a charge poorly. The mahcine thinks its run out of water and reacts accordingly...
    I find that descaler does a pretty nice job of a probe when I do a Giotto descale ;)
    Apr 2007
    399
    Thanks for the reply Chris
    the machine gets descaled once a year, backflushed with water every day and with chemical once a week or fortnight depending on how many coffees i make.
    Water i use a britta jug, 1 pass through only and put fresh water in the tank every second day.
    Still the probe get black and mucky very quickly.
    As mentioned, once cleaned, its fine for a few months but then does it again. I figure if its a water (filtering problem) it may have done it even more often. I could be wrong of course.
    Never use to be this bad before.
    Should i try just using tap water instead
    14,665
    No worries John,
    The more I see the effects of brita jugs on espresso machines, the less I think that they actually do anything useful at all...
    I have seen a heap of machines with tank couplings fill of black gunk (carbon) and one boiler where it was about 1cm deep in the bottom.
    I think that coffee specific filtration using good filters is the way to go.
    Apr 2007
    399
    Thanks again Chris
    will look into a proper filtration system then and see if that changes things
    Any recommendations?
    14,665
    Quote Originally Posted by 5C797E7857160 link=1277789942/4#4 date=1277869551
    Thanks again Chris
    Hi John,
    Try http://coffeesnobs.com.au/YaBB.pl?num=1245022813
    I have just spliced a a Bombore Scale stopper filter into the line running to my cold tap....Everything which comes out of the tap is ready to roll and it tastes great too ;)
    We have a few in stock...
  1. Boiler water level probe
    By JohnA in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st June 2013, 05:56 PM
  2. cleaning water tank and water carrying tubes of Rancilio Silvia from "gunk" ?
    By acid_rider in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 21st September 2012, 10:24 PM
  3. Giotto Evo water level probe height
    By nixter in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 22nd October 2011, 02:41 AM
  4. Using hot water in water tank for improved temperature stability?
    By jsrenaud in forum Brewing Equipment (non-machine specific)
    Last Post: 4th July 2011, 03:16 PM
  5. Question about drawing water now that I have replaced the in tank water softner
    By barrel in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 24th August 2009, 09:43 PM
