Results 1 to 6 of 6
Thread: swapping out an anti-vac valve on VBM Super
    Jun 2008
    16
    Hi All,
    Ive had a search through the forum to see if I can locate a how to for replacing an anti-vac valve on the VBM.
    so far, no success which leads me to 2 possible conclusions:
    1) it really is as simple as it looks - unscrew, throw away, screw in replacement.
    or
    2) You fool! only qualified engineers with 20 years + advanced boiler maintenance should even considder attempting such a feat (and they best be well paid up on their life insurance before trying)
    so... which is it?
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: swapping out an anti-vac valve on VBM Super
    Neither..
    1: Unscrew, clean up any scale and toss away the old O-ring
    2: Replace o-ring, screw back in.
    PS. Use a tea light casing to make a neat little spill catcher, if you do not already have one ;)
    Quote Originally Posted by 7A455F4F495E4D2C0 link=1279543981/0#0 date=1279543981
    Only if ya start touching any thing electrical... The moment ya do... Then get it tested before powering back on.
    Jun 2008
    16
    Thanks for the swift response AM.
    from what youve written, its only a case of replacing the o-ring and not the entire valve? :o
    or is that just a cost saving interim step to try to fix any issues without going the whole hog?
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 4C7369797F687B1A0 link=1279543981/2#2 date=1279545322
    from what youve written, its only a case of replacing the o-ring and not the entire valve? *:o
    Depends on what the issues are..
    In many cases, it is just a clean that might be required..
    OR
    http://coffeesnobs.com.au/YaBB.pl?num=1226636581/4#4
    For a close up of a Anti Vac valve... http://coffeetime.wikidot.com/vacuum-breaker
    May 2008
    600
    unless your haqppy to take off and put on a few times til you get it right, id just buy a whole new anti vac valve. like you say, unscrew and put the new one on. it might havve copper washer, or you might need some plumbing tape or pipe sealant.
    Jun 2008
    16
    Quote Originally Posted by 5D727B796E517D727D7B79717972681C0 link=1279543981/3#3 date=1279589367
    For a close up of a Anti Vac valve...http://coffeetime.wikidot.com/vacuum-breaker *
    Now THAT is exactly what Ive been looking for! Thank you kindly.
    ... and if id known it was also called a vacuum breaker i probably could have found this without bothering you :-[
  1. Anti-vac valve
    By skydragondave in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 16th January 2013, 11:04 PM
  2. Sticky La Cimbali Anti-Vacuum Valve
    By GCM58 in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 27th September 2011, 08:18 PM
  3. Anti Suction Valve Leak
    By ento in forum Brewing Equipment (non-machine specific)
    Last Post: 30th January 2009, 12:02 PM
  4. Giotto problem - anti vacuum valve?
    By beetle in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 3rd December 2008, 11:43 AM
  5. leaking valve - new VBM domobar super
    By bieman in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 8th November 2008, 03:19 PM
