Results 1 to 13 of 13
Thread: Help with steam pressure on bezzera Domus Galatea!
    May 2008
    14
    Ive had this machine for about a month now, and am very happy except...
    Every third jug of milk I go to steam it de-pressurises, and the steam pressure drops to zero. It then takes a minute or so to get back up to reasonable pressure. It seems to make no difference if the machines been on for 10 mins or 3 hours. Or whether Ive just poured one coffee or three.
    Is this a recognized fault?? Im not too keen to return it if I can help it, as Im otherwise quite attached! :)
    Senior Member SniffCoffee's Avatar
    May 2010
    Canberra
    703
    Re: Help with steam pressure on bezzera Donus Galatea!
    Hi there
    How much milk are you steaming each time?
    May 2008
    14
    Maybe 200-300ml. It doesnt matter though, cos the pressure drop is instantaneous. The gauge goes from ~1.3 bar to zero in less than a second. Other times its fine regardless of volume
    Apr 2008
    Brisbane
    5,113
    You may need to adjust the boiler water level
    Hope this explanation makes sense
    You need to have less water in the boiler to make more space available in the boiler for more steam
    Jul 2009
    252
    Souds like a sticking vacuum breaker, found on top of boiler usually.Either clean and replace o-ring, or replace complete vac breaker (usually around $20)
    Apr 2008
    Brisbane
    5,113
    Quote Originally Posted by 5E5A53505E5C4141350 link=1311383000/4#4 date=1311394275
    Sounds like a sticking vacuum breaker, found on top of boiler usually.Either clean and replace o-ring, or replace complete vac breaker (usually around $20)
    Yes another possibility
    Excellent advice from kofekitt
    May 2008
    14
    Thanks for the advice..... Im going to take it back to coffee craft to get them to sort it... Seeing as its a new machine and all. I was mainly checking that dodgy steaming performance wasnt an expected feature.
    Thanks heaps
    senior member
    Mar 2008
    Perth
    150
    certainly not - the Galatea has plenty of steam!
    Aug 2004
    2,312
    Quote Originally Posted by 6065696D656A676865766F040 link=1311383000/2#2 date=1311389258
    ..... the pressure drop is instantaneous. The gauge goes from ~1.3 bar to zero in less than a second. Other times its fine regardless of volume.....
    Yes, the best advice is to take it back.
    Be careful....we see enough threads like this in CS, asking for advice on problems before equipment is taken in for repair.* Dont expect the problem to be anything anyone has kindly advised you of...it might be something mentioned here, and it may not.
    Allow your suppliers guarantee to work for you which is to protect you against faulty manufacture and assembly in a new machine, and let the repairer do his job without second guesses coming from the sidelines* ;)
    Afterwards, I for one would be interested to hear what the problem really was, and look forward to your update :)
    Rgdz,
    Attilio
    very first CS site sponsor.
    Aug 2009
    469
    yep, certainly a puzzler!
    May 2008
    14
    Re: Help with steam pressure on bezzera Domus Galatea!
    Thanks .... This was my reason for buying local. Even though its a pain to put in the car, its better than having to post it away!
    Nov 2010
    Adelaide
    364
    How did you get on Damian?
    May 2008
    14
    After 2 LONG weeks waiting I finally got it back. I think they had some trouble finding the fault also.
    The docket says parts: vacc valve, non return valve ass, o ring.
    Then it says:
    -replaced suspect parts
    -descaled vacc assembly
    -adjusted relief valve
    -bench test/diagnostics
    Doesnt mean too much to me, but it works just fine now!!
    After 2 weeks of plunger I was about to go crazy!!
  1. Bezzera Domus Galatea Boiler Pressure
    By fancypants in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 22nd June 2015, 09:15 AM
  2. Bezzera Domus Galatea pressure
    By robcav in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 28th May 2011, 01:26 AM
  3. Bezzera Domus Galatea 2 hole steam tip.
    By beanz4brainz in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 22nd May 2008, 09:36 PM
