Results 1 to 6 of 6
Thread: Giotto light not working
    Aug 2011
    5
    Im new to posting but have just bout a Giotto premium plus About a year old from eBay.
    Issue I am having is the green light for power and water sensor light is not working. Anyone know what I need to fix, supplier and estimation what cost Im up for?
    Thanks in advance.
    14,665
    Re: Giotto light not working
    Quote Originally Posted by 04213B3C2D262D3A480 link=1313358489/0#0 date=1313358489
    Thanks in advance.
    Easy fix in 15-30 minutes. The globe assembly is about $20 I think.
    Have it checked at the same time. If you see black and grey wires leading to the pressurestat, ask your tech to rewire it to current spec. It might save you replacement of a control board at some poiint in the future.
    Aug 2011
    5
    Thanks Chris.
    So is it easy enough for an ameteur like me to open up and replace or do you suggest I get a technician to do the work?
    Regarding the pressure stat why would it require to be rewired to current spec since Im assuming it is current spec being only a year old?
    14,665
    Quote Originally Posted by 0F2A3037262D2631430 link=1313358489/2#2 date=1313377218
    Thanks Chris.
    I would not recommend that an unqualified person open any machine and we certainly would not supply the part.
    My apologies. I read Giotto Premium. All Premium Plus machines are fine :)
    Aug 2011
    5
    Thanks for the advice
    Senior Member Beanz.'s Avatar
    Apr 2009
    227
    Quote Originally Posted by 16232E291D012D24242727420 link=1313358489/1#1 date=1313359405
    Hi Chris
    Can you please clarify which models or year of manufacture require rewiring.
    Are there specific serial numbers that can be checked ?
    What is the fault that can develop in the wiring harness that potentially takes out the control board ?
  1. Giotto premium vibratory pump not working
    By Listener in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 8th September 2011, 09:32 AM
  2. Isomac Tea - green light not working
    By Pawnii in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 11th July 2011, 06:34 PM
  3. Giotto light on but nobody home
    By el_espressio in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 9th November 2010, 02:13 PM
  4. Giotto Not working
    By skinnyflatwhite in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 18th April 2007, 11:20 AM
