Results 1 to 2 of 2
Thread: Futurmat Ariete 1gr - how to handle tripped Level Safety device
    nkb
    nkb is offline
    Oct 2011
    2
    Dear all,
    The LED´S of all touch pads are blinking. And the only touch pad that functions is the one for “Continuous brew “. The automatic refilling of the boilertank does not function but heat is ok.
    How do I handle this tripped Level Safety deviice - Do I need to change a component?
    Niels
    Sep 2011
    68
    Re: Futurmat Ariete 1gr - how to handle tripped Level Safety device
    Quote Originally Posted by 3431385A0 link=1317485045/0#0 date=1317485045
    Niels,
    It sounds like the control box has gone on your machine. The quickest solution is to simply replace it. The cheaper one (works often but not always), is to check the capacitors etc on the board. Often you can get it all working again by simply replacing a few components on the board.
    I do this myself quite often (for myself and others), and works about 80% of the time.
  1. Keypads are flashing on my Futurmat Ariete 1 grp.
    By nkb in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 5th October 2011, 07:19 AM
  2. Just got a 2 grp futurmat! any knowledge 2 share?
    By MachoSilvia in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 9th October 2007, 04:39 PM
  3. My 20 yr old Mas tripped the Earth Leakage
    By TEPIN in forum Brewing Equipment (non-machine specific)
    Last Post: 26th June 2006, 07:01 PM
