Results 1 to 4 of 4
Thread: Giotto Evo water level probe height
    Jun 2010
    26
    Ive had a lack of steam lately so I removed the top of my machine. I noticed that the probe was inserted pretty much as far as it could go. The flat end of the probe was right up to the nylon sheath. I also noted that the probe nut was loose enough that the probe could slide up and down VERY easily. Im wondering if my probe could have been moved during one of the times of had the top off previously. It seems very likely given how close the probe and its wires are to the metal plate that attaches just above it. I could have easily knocked the probe during removal or re-installation of the plate. So can anyone tell me what the correct height should be? Or if anyone has a photo that would be even handier!
    N
    P.S. I couldnt find a search button anywhere other than the quick google search. Am I blind?
    14,665
    Re: Giotto Evo water level probe height
    Hi nixter,
    When the probe gets wet feet, the boiler stops filling so yours is in the correct position to maximise steam capacity.
    Dec 2004
    Earth!
    15,584
    Quote Originally Posted by 2D2A3B372631430 link=1319135726/0#0 date=1319135726
    Nope, youre not blind. :) The YaBB search button was removed quite some time ago.
    Java "Search engines are (Can be!) your friends." phile
    Jun 2010
    26
    Quote Originally Posted by 6A4156415048494C45200 link=1319135726/2#2 date=1319144756
    Ok thanks! And yet I sometimes run out of steam when trying steam a small amount of milk for a flat white. Anyhow, I removed the whole probe assembly, cleaned it, etc. I have my max pressure set at 1.1 so maybe Ill try 1.2
  1. Boiler water level probe
    By JohnA in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st June 2013, 06:56 PM
  2. Minore II - Steam water level adjustment
    By danzx6r in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 10th February 2013, 01:28 AM
  3. Water level controler concept
    By Kerenfood in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 22nd March 2011, 09:38 AM
  4. Water Tank probe
    Last Post: 30th June 2010, 02:18 PM
  5. Rancilio S26 -Boiler Water Level
    By Sacred_Cow in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 26th October 2009, 09:30 PM
