Results 1 to 4 of 4
Thread: VBM JNR STEAM VALVE DRAMAS
    Apr 2010
    107
    I just went to the kitchen to make a coffee to find all the gauges fogged up with condensation and immediately smelt a rat (not lit.). And next i found that the water level light was on and i was sure there was plenty of water in it a couple of hours ago. So i refilled her and the element kicked in but it didnt create much pressure before a loud sharp hiss came from inside. Turned off and pulled apart and it seems the valve at the top of the boiler is not doing what its meant to, ie. its not locking under low pressure. Any diarrheas? ::)
    14,666
    Re: VBM JNR STEAM VALVE DRAMAS
    Quote Originally Posted by 6F74757E7E1B0 link=1320662675/0#0 date=1320662675
    I just went to the kitchen to make a coffee to find all the gauges fogged up with condensation and immediately smelt a rat (not lit.). And next i found that the water level light was on and i was sure there was plenty of water in it a couple of hours ago. So i refilled her and the element kicked in but it didnt create much pressure before a loud sharp hiss came from inside. Turned off and pulled apart and it seems the valve at the top of the boiler is not doing what its meant to, ie. its not locking under low pressure. Any diarrheas? ::)*
    Almost certainly a failed anti-vac tonee if its venting at low pressure.
    Apr 2010
    107
    cheers ....does the new one just screw in?
    Apr 2010
    107
    got it fixed thanks to coffee parts xclnt service and your guidance cjn.
    tyvm ;)
  1. Faema Legend steam valve
    By walshman in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 22nd August 2012, 04:33 AM
  2. Silvias steam valve
    By Clonetrooper in forum Brewing Equipment (non-machine specific)
    Last Post: 12th September 2006, 10:07 PM
