Results 1 to 8 of 8
Thread: Newbie to BZ99 needs help
    Dec 2011
    2
    Hi All
    I think this post is in the right forum if it isnt please let me know. Im in Liverpool UK and have acquired a Bezzera* BZ99 and need some assistance with it.
    It is a 1.3Kw 2001 model with a single dial pressure gauge
    When I tried to turn it on there was a clicking noise, like a relay, and it wouldnt stay on. Eventually when it did and I pressed the green button I got hot water out of the*group head. When I used the steamer or hot water the pressure didnt stay stay constant, dropped to nil and didnt repressurise.
    When I tried it the next time it tripped out the ring main in the house. It done this three times. I got a friend to help me out who has some electrical knowledge and we stripped it down and tested the circuits on the machine and the element.* All seemed ok.
    I havent tried the machine since we put it back together again as I suspect the the pump should be primed before use and I dont know how to do it.
    Does anyone have a readable user manual which can be of assistance and give me any advice on where I should go from here.
    Site Sponsor
    Aug 2006
    1
    Re: Newbie to BZ99 needs help
    It could be at simple that your ON/OFF switch is in his way out. If is not that you should take it to your local repair center, they should be able to test a few things and sort it out for you.
    If you want the diagrams of you machine shoot me an email, happy to share. renzo@unpaid.com.au
    Regards
    Renzo
    Dec 2011
    2
    Hi Renzo,
    Thanks for trhe prompt reply.
    Id managed to get diagrams from* bezzeracoffeemachine.com.au, although what would be really useful is a user manual if one exists.
    These machines seem to be quite a rarity in the UK. Theres only one or two places nationally which supply parts but seem to have no knowledge of the working of the BZ99. One which was selling a heating element even asked me for copies of the diagrams I had!
    Before I switch it on again could you tell me how to prime the pump or is it self priming?* Also, what should I see and hear regarding the orange and green switches and should I hear the pump working?
    Site Sponsor
    Aug 2006
    1
    This machine is self prime.
    When you turn your machine ON- the orange light and the green light will turn ON as well.
    This machine will prime his self if water is needed on the boiler.
    I reckon you should take it to your local repair and ask him for a general service to check everything.
    Renzo
    Nov 2010
    Adelaide
    369
    I also own a BZ99 (plumbed in model) and acquired it about 6 months ago. Theyre a beautiful machine. I echo Renzos comments unless you really know what yourre doing, take it to someone who does it for a living. Long term its probably cheaper as they may discover something about to break or just give it a good general service that may prevent something from breaking down the track.
    Jan 2014
    1
    Hi Cybersurfer,
    I have a BZ 99 and can send you a pdf of the manual if you still need it.
    Dec 2004
    Earth!
    16,034
    I think you'll find all the docs for the BZ99 are available in the pointy end documentation section: Documentation - Pointy end
    Java "More data!" phile
    Toys! I must have new toys!!!
    Oct 2011
    1,376
    I hope the OP has figured out how to use the machine by now anyway
    They aren't that complicated - 3 years should be long enough
  1. Bezzera BZ99 Help!
    By minvec in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 5th July 2014, 02:02 PM
  2. BEZZERA BZ99 HELP ME PLEASE !!!!
    By coolecter in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 30th November 2012, 06:12 PM
  3. Would you pay this much for a Bezzera BZ99?
    By mum2three in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 22nd January 2010, 06:56 PM
  4. Help with hot BZ99
    By patro5 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 17th August 2009, 04:51 PM
  5. all BZ99 users
    By talbashan in forum Brewing Equipment (non-machine specific)
    Last Post: 26th December 2006, 09:38 PM
