Results 1 to 3 of 3
Thread: Slight leak from Isomac pump found.
    Jan 2012
    40
    Anyone had a leak coming from where the threaded union connects to the pump?
    I noticed it today when adjusting my OPV. Its only a slight leak so I think i should be able to seal it easy enough.
    Aug 2004
    2,312
    Re: Slight leak from Isomac pump found.
    Careful you dont crack anything which is relatively easily done in these situations
    Careful you dont void your warranty (if the machine is still in...)
    Careful you dont electro-kill yourself
    Jan 2012
    40
    Im not going to remove it, just seal it. Its not much of a drip at all.
    Good warnings though!
  1. Procon pump leak
    By towe0609 in forum Brewing Equipment (non-machine specific)
    Last Post: 21st June 2012, 08:46 PM
  2. Humming/Slight vibration from 6910 when off?
    By javaboy in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 20th February 2008, 03:45 PM
  3. Gaggia Classic pump leak
    By dkelly60 in forum Brewing Equipment (non-machine specific)
    Last Post: 4th October 2006, 11:10 PM
