Results 1 to 10 of 10
Thread: HELP! Machine went up in smoke ( Maver Marte)
    Mar 2008
    120
    Hi all!
    My trusted and favourite Maver Marte got burnt today ;-( Literally went up in smoke! And I think I saw a bit of flame too. I think it could be that some water sipped through inside and its only my fault.
    I turned the power off quickly and took in apart. I quickly found the source of fire and smoke, but to be honest I have no idea what this part is.
    The machine is not under warranty anymore. Could someone perhaps tell me straight away what XP700 is and how/where to replace it and how much it may cost. I live in Melbourne.
    Attached photos show where the part is
    I will be so grateful if someone could help with the problem.
    I know that I should probably call Veneziano as they surely know this machine... any ideas?
    Ed
    14,665
    Re: HELP! Machine went up in smoke ( Maver Marte)
    Hi Ed,
    Not the end of the world...
    The nuked part is the pressurestat and the best bloke to talk to will be Craig of 9bar Espresso services (<<<<<site sponsor)..
    Unless something else is cooked, its a 15 minute job and pressurestats are not that expensive...
    2mcm
    Mar 2008
    120
    thanks 2mcm,
    I will give Craig a call tomorrow
    Ed
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 0E51495F545F535A5A5959515D523C0 link=1259831284/1#1 date=1259831571
    Hi Ed,
    2mcm
    Yea I understand that this is a weak spot on these units... Trust the new part is beefed up ...
    Senior Member Coffee2Di4's Avatar
    Sep 2008
    Ipswich, QLD
    1,472
    I feel for your loss... :(
    However, if its not repairable, bags first dibs on the group handles, water tank, control board, etc! ;D (Only joking, I need as many Maver Compadres out there as I can get!)
    Please let me know how you go and if Craig says what may have caused it so I can avoid it myself.
    Di
    Mar 2008
    120
    should have said earlier...
    all was fixed and all is fine now. Thanks Craig!
    Sep 2008
    Ipswich, QLD
    1,472
    Excellent, thanks Chartres - did Craig give you a diagnosis at all of what caused the fire?
    Di
    14,665
    Quote Originally Posted by 012630223A490 link=1259831284/6#6 date=1260948025
    Di
    I am pretty sure it was the element relay Di.
    On the Maver, some Diademas and Bezzeras, its located on the pressurestat and encounters pretty high load being switched frequently. Fortunately, pressurestats are relatively inexpensive and easy to replace.
    They can go bang, often with a spark and associated carbon when they die but a fire is *:o :o.
    Ill be keen to hear Craigs diagosis as well.
    Mar 2008
    120
    well, I saw some flames through these little gaps in the panels, but I didnt say it was "a fire" as such. It was more like a sizeable match was burning inside. After the pressurestat was replaced everything seems to be ok, or almost everything.
    My pressure gauge for boiler pressure wasnt working before I think and it is still not working ;-)
    But now another gauge (brew pressure) is giving strange readings together with pump going silent when brewing, at times(more than 11 bar, but I dont trust the gauge now as coffee doesnt seem overextracted ) and I want to pay Graig another quick visit to check whats up. Its not related to the initial fault I think.
    Site Sponsor
    Sep 2009
    52 Gaine Rd, Dandenong South. VIC 3164
    17
    Hi Guys,
    Spot on with the diagnosis Chris.
    Its just poorly designed not really much you can do to avoid it! Thanks for all the support guys.
    Craig
  1. Maver Marte/Makin Espresso Review
    By luca in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 2nd October 2011, 07:20 PM
  2. Maver Marte - Vibration Damping?
    By Coffee2Di4 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 17th June 2009, 07:29 PM
  3. Analyse This! Makin Maver Marte and Macap M4...
    Last Post: 3rd June 2009, 09:06 AM
  4. [m]: Re: Maver Marte/Makin Espresso Review
    By TC in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 30th November 2007, 10:31 AM
