Results 1 to 16 of 16
Thread: Help Please Faema e98 S1
    Jan 2007
    10
    I am hoping that this is a newbie question!
    My wonderful little machine has stopped boiling. It would appear the thermostat has given up on me. I can pump water, get a flow through the head but nothing else.
    I have taken the sides off and had a look to see if there is a reset switch somewhere put can not find one. Is there such as thing?
    Any pointers? thanks in advance.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Help Please Faema e98 S1
    Quote Originally Posted by 53717A771E0 link=1265065342/0#0 date=1265065342
    And what lights are showing ?
    It could be the thermostat / Element / any number of minor things...
    Where are you located.. Could be a sponsor; just down the road...
    Jan 2007
    10
    Thanks for the quick response.
    I have the green light showing.
    Located in Berowra NSW. North of Hornsby.
    levercrema
    Quote Originally Posted by 06242F224B0 link=1265065342/0#0 date=1265065342
    Also you might get more responses in the 3g pointy end.
    Sounds like youve had the machine a while so this is probably a stupid suggestion - but did you turn the on/off switch all the way to 2? Position 1 gives you everything but the heater. 2 adds the element - a few times Ive come out bleary eyed and desperate for a coffee and neglected to go all the way :o
    Jan 2007
    10
    Yeah, thanks. Had the machine for a few years now. So yes it is on position 2. I have done some more web searching and have not had too much luck.. Looks like I may need to find a repairer near by. Can anyone recommend a good place that will look after me (ie not rip me off) I live north of Sydney and am happy to travel to go to a good place.
    Jun 2008
    1,520
    jetblack or sibonis in the sponsor list might be closest ?
    also sent you a PM about a non sponsor mob
    hope you sort it out.......
    levercrema
    There is a re-set button on the thermostat - right hand side.
    Jan 2007
    10
    Quote Originally Posted by 222B382B3C2D3C2B232F4E0 link=1265065342/6#6 date=1265089294
    Thanks. Will see if I can find it. Is is obvious?
    levercrema
    Quote Originally Posted by 507279741D0 link=1265065342/7#7 date=1265090587
    Turn the power off! Looking at the front of the machine, take the right hand cover off. Youll need an alan key for the single spring loaded screw in the top. The Thermostat is immediately under the end of the element end-plate. Theres a big red button in the middle. Push it - not hard. If its popped it should only need a touch to get it back in.
    All this is assuming its the same as my E98 S. I think the earlier ones had the reset on the end plate. It shows you in the manual.
    Goodluck,
    Don
    Jan 2007
    10
    Goodluck,
    Don
    Thanks Don,
    Yes we have the same machine. I found the thermostat but no such luck. It wasnt tripped. Looks like it might be something a little more expensive *:-[
    Will follow up maheel suggestions.
    Thanks all.
    Site Sponsor
    Aug 2006
    929
    Modi,
    You should try harder to push this one, sometimes is not as soft as appears, happen once to me.
    Regards
    Renzo
    Jan 2007
    10
    Thanks Di, I did give it a fairly hard push, there was a little give, but it would appear that it was already in the "on" position. It may not be a thermostat issue after all.
    The other thing is that I have had the machine for at least three years now so maybe it is time I took it in for a service.
    thanks
    A_M
    A_M is offline
    Mar 2006
    6,381
    Depending on what water and what maintenance / cleaning / flushing you have done over the last 3 years.
    A service would be a top priorty..
    Jan 2007
    10
    I will get it in for a service. But I have always kept it clean done a daily flush. So it has been looked after. But off to the service shop I go.
    A_M
    A_M is offline
    Mar 2006
    6,381
    A flush is one thing a true chemical clean etc is all together diferent..
    Apr 2007
    Sydney - Northern Beaches
    412
    Im very interested in how you get on with this as I have the exact same machine. No problems yet touch wood but I would be interested in hearing how the service goes and what it costs.
  1. Help needed with another Faema e87
    By faemaE87Novice in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 23rd March 2010, 05:52 PM
  2. Anyone Have an old Faema?
    By Aaron in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 16th May 2009, 08:14 AM
  3. Faema A6
    By No1Daemon in forum Grinders
    Last Post: 17th July 2008, 03:40 PM
