Results 1 to 13 of 13
Thread: Have I Wrecked my ECM Giotto - Help
    Jan 2007
    35
    I have just replaced a faulty safety valve on my ECM Giotto. The safety valve was very tight and in trying to loosten it, the wrench slipped and broke of the thermostat. Normally the thermostat screws into the boiler but the section that is screwed into the hole in the boiler has broken off, thus filling the hole. Therefore I can not just replace the thermostat as there is no longer place to screw it in. I have attached a picture. Can anyone help? Does anyone have any suggestions? What can I do?
    CoffeeNcake :(
    Dec 2009
    104
    Re: Have I Wrecked my ECM Giotto - Help
    I would be thinking, drill it out and re tap it, but then again I am not a professional and this could ruin it, and I would only do that as a last measure.
    Caffeine Junky
    May 2009
    1,103
    AM where are you?
    It may be a little fiddly/tricky but Im sure its do-able. If youre not very handy just take it to a pro.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 212D242427270C21232927420 link=1273833995/0#0 date=1273833995
    *Can anyone help? *Does anyone have any suggestions?
    AND
    Quote Originally Posted by 282923302E2B31420 link=1273833995/2#2 date=1273836492
    It may be a little fiddly/tricky but Im sure its do-able. *If youre not very handy just take it to a pro.
    So where are you located... coffeeNcake
    1: Are you not happy that as a Qualified person you took the time to disconnect and to de energise..
    2: Zap BANG YA DEAD....
    Yes it can be fixed in about 5 min *;D
    What... Ya not next door ?
    Who ya gunna call then...
    A: New item required.
    b: Good quality metal twist drill that is smaller than the thread
    c: Small pistol drill or a hand drill
    d: Small easy out
    e: Maybe a dremal to grind flat prior to marking the centre part for the drill
    OR even a fine centre punch to use as a punch
    OR a cutting blade on a dremal and make a slot for a driver...
    OR A drill and tap to suit the replacement part
    Or .......
    Many ways to skin a cat but ya need to have it in ya hands to work out the best way...
    Jan 2007
    35
    I live in Melbourne.
    cNc
    Sep 2008
    239
    Mate AM has the right ideas as usual, an easy out or cutting a slot for a screwdriver sound like great ideas but if you are in any doubt at all about having a go at it then give Chris a Talk Coffee a call for help seeing as you are in Melbourne. They boys at 9Bar would be another option.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 383B28283F365A0 link=1273833995/5#5 date=1273848827
    Couple of excellent service and switched on people there and access to all the tools is a big plus...
    Jan 2007
    35
    Thank you all. I think I will get someone with more experience than me to do it. The scew is very fine and I dont want to make a bigger mess of it than what has already been done.
    I called Chris today - he also felt that getting the tiny screw out was out of his area of comfort.
    I tried to call 9Bar but as it was Saturday they were closed. I will try to call them on monday.
    If 9Bar can not do it does anyone know someone in Melbourne to do this sort of fiddly job.
    Thank you
    cNc
    Mar 2009
    565
    I would think that any fitter & turner or machine shop could do it.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 614D4E4B4C7D75220 link=1273833995/8#8 date=1273886335
    Ya ... Just make sure they are into fine work and not mining gear :-)
    Mar 2004
    Internet
    17,011
    Blog Entries
    1
    Another vote for the "ezy out" from me. Years of repairing motorcycles means that I always have a few kicking around.
    FYI they look like...
    I once had and ezy-out breakoff inside the drilled bolt... shudder... it then took hours to repair because of the hardness of the ezy-out.
    Pity they dont make an ezy-out-ezy-out
    If you are not comfortable doing this yourself then professional help is certainly best.
    9Bar will do it easily... its the sort of thing that they come across all the time in the repair game. Give em a hollar on Monday and Im sure they will be able to help.
    8-)
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 1D3238255C0 link=1273833995/10#10 date=1273900450
    giggled like a schoolgirl..
    OH so true...
    Tight Oh so tight... Now do I give a bit extra or do I undo, and go up a size..
    Na... It has to come... Besides whats another fraction of a turn... It moving, I know it is...
    BUgger ^$#@^#% ^%#@%# * &^$#^%#^#%
    WHY did I just do that !!!!!!!!
    Once had 3 sets.. Now have a box of different sizes *and some have been ground down and rather short *::)
    They also make great pin punches due the their hardness...
    Quote Originally Posted by 012E2439400 link=1273833995/10#10 date=1273900450
    Solo or club; if club, what rank ?
    Ex Sgt.
    KJM
    KJM is offline
    May 2007
    688
    While they are rare as hens teeth in Australia for some bizarre reason - left hand drill bits are unbelievably good at getting the fastener out.
    The LH action plus the vibration and heat from the drill causes the fastener to come out while being drilled most of the time. *Avoids the same relationship I have with easy outs that AM has :(
    I just dont understand why these things cost $change in the US, but are seriously expensive over here!
    /Kevin
  1. Giotto PP vs Giotto Evoluzione
    By julesinoz2010 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 25th January 2011, 01:25 AM
  2. question - Giotto PP or giotto premium?
    By cafe_lover in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 30th January 2010, 12:16 PM
  3. Giotto help please
    By Lovey in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 1st November 2008, 05:43 PM
