Results 1 to 5 of 5
Thread: VBM Piccolo group head gasket size?
    May 2008
    16
    Time to replace the group head gasket on my Lavetta/Piccolo.
    I realise it there is a 8mm and a 8.5mm size in the coffeeparts website.
    Which one should I buy?
    Also, is it advisable to change the shower screen as well?
    Any help would be greatly appreciated!
    Joe :D
    10,496
    Re: VBM Piccolo group head gasket size?
    Take the old one off and see if it is marked with the size.
    Failing that, write to/ring Pedro and ask him.
    I dont know why youd need to change the shower screen unless it was damaged.
    Mar 2008
    554
    If the Piccolo has the same screen with the metal rim on the face of the screen spot welded as the DS comes with in the States (and I would assume that it does), go ahead and change it. There is a quality replacement available that can be identified by a sort of indentation that goes all the way around the circumference of he body, about 3 or 4 mm above the face. It is much stronger and much easier to remove, and doesnt dent so easily as the original.
    The DS takes an 8.5mm gasket. I dont know about yours.
    Site Sponsor
    Aug 2006
    929
    Joe;
    Try by using the 8mm and get an spacer in case.
    http://www.dibartoli.com.au/product_details.asp?pid=284
    http://www.dibartoli.com.au/product_details.asp?pid=197
    Regards
    Renzo
    Di Bartoli Home Barista (Spare Parts Dept)
    May 2008
    16
    Thanks for the replies will probably go with the 8mm + spacer.
  1. Saeco Via Venezia Group Head Gasket
    By Cavarna in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 28th October 2014, 07:25 PM
  2. Replaced group head gasket on Rancilio Silvia: was leaky now a spray!
    By markjd in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 6th April 2012, 01:08 PM
  3. When to change the group head gasket?
    By nobby_s_beans in forum Brewing Equipment (non-machine specific)
    Last Post: 5th November 2005, 06:35 PM
