Results 1 to 8 of 8
Thread: Help!! Bezzera Plumb In!
    Aug 2010
    20
    I have recently purchased a Bezzera bz35e-mg and a Bezerra BB95 coffee grinder. However, the dilemma is i can not plumb it in is there any way i can hook the machine to a bucket or something cause im desperate!!!
    Aug 2004
    2,312
    Re: Help!! Bezzera Plumb In!
    Contact Bezzera importer listed amongst the site sponsors at left<<<<<<<<<<<&l t;<< and trading as Barazi Bezzera Coffee Machines
    Hope this helps.
    Rgdz,
    Attilio
    very first CS site sponsor
    Jun 2008
    1,520
    yes you can
    do a search, read a few of the $3000+ threads about it.
    there are a few issues around pump pressure and keeping pump primed etc
    Aug 2010
    20
    Could you provide a link please :)
    Regards,
    Orlando
    Jun 2008
    1,520
    your going to have to do some reading.....
    the basics are
    it will work
    you need to keep the pump primed as rotarys dont like self priming
    either water above / beside pump or backflow preventer in the line
    or maybe small presurre pump on the tank
    you will need to check pump pressure @ 9bar ish scace or home made gauge, i fit was plumbed prior you need to adjust it.
    whats your location?
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 282D312E362B282F3E2B5B0 link=1285743713/3#3 date=1285802401
    Could you provide a link please *:)
    Regards,
    Orlando
    http://coffeesnobs.com.au/YaBB.pl?num=1248646363
    Jul 2008
    Port Fairy
    2,993
    Either use Google to search or use the advanced site search.
    As you sound like you need complete help a sponsor visit for a chat might be in order. As Maheel has mentioned Yes it certainly can be done with a plastic tank and a few valves and fittings.
    I am running my 3 group on a tank and pump but the pump is below the water level so I dont heve the pump issue. I will be setting up another machine at home next week but it too will have an external pump and tank (both on the floor in a rental property.
    The real key is eliminating airlocks and keeping the pump primed :)
    Aug 2010
    20
    Quote Originally Posted by 5559505D5D54380 link=1285743713/4#4 date=1285802738
    I am located in Lidcombe,Sydney NSW
  1. Minimum pipe size for plumb in rotary pump machine
    By maheel in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 11th November 2010, 09:19 AM
  2. Hole Size for Plumb-In
    By Seeya_Latte in forum Brewing Equipment (non-machine specific)
    Last Post: 26th February 2010, 11:24 AM
  3. Giotto Plumb In Kit
    By Vertullo in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 30th September 2008, 03:23 PM
