Results 1 to 6 of 6
Thread: Bezzera BZ99 Cutting out / Overheating?
    Aug 2008
    20
    Ive had a 2nd hand BZ99 for about 6 months and its developed a problem whereby it will appear to overheat and not allow the pump or heating element to run. In essense the green light goes out, just like a low water cut-off.
    If I let it cool for about 30 minutes its all good again.
    Any ideas where to start looking here. Ive had a look at google and also the threads here, but cant seem to find the same problem anywhere.
    Im guessing the 3 obvious things could be:
    a) the sensor detecting "too hot" is cutting in too early
    b) the pressurestat is faulty allowing the unit to heat too much, although it does cut in and out regularly, not stay on continuously.
    c) I suppose it could be a fault with the low water sensor or connections that only triggers when temp is high!
    Any comments welcome. Id like to try to fix myself if possible.
    Dwight
    Site Sponsor
    Aug 2006
    1
    Re: Bezzera BZ99 Cutting out / Overheating?
    Hi Dwight;
    Looks like your control board is in his way out. I will suggest to take your machine to your local technician.
    Regards
    Renzo
    Apr 2012
    319
    How did you go with this problem?
    I am looking at purchasing a 2nd hand BZ99. Reading through other peoples posts they seem to be a pretty good reliable machine. How did you find its performance prior to these problems?
    If you want to let it go I would be interested :)
    Regards Brendon
    Apr 2012
    12
    Hi
    Just wondering what the problem turned out to be
    Please let me know
    Aug 2008
    20
    Sorry for the lack of replies guys.
    My machine was too far gone to effectively repair. It was a control board needing replacement, but as the machine was not near new it wasn't worth going down that path.
    I might put the machine up for sale in the hardware forum for those who might want parts.
    Oct 2011
    1,376
    Sorry to hear that.
    I'd possibly be interested in parts. Is it the vibe pump or rotary pump version?
  1. BEZZERA BZ99 HELP ME PLEASE !!!!
    By coolecter in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 30th November 2012, 06:12 PM
  2. Bezzera BZ99 How To Fix It?
    By philschl in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 28th October 2011, 07:58 PM
  3. Would you pay this much for a Bezzera BZ99?
    By mum2three in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 22nd January 2010, 06:56 PM
