Results 1 to 6 of 6
Thread: Izzo Vivi MK 1: boiler level solenoid?
    Dec 2009
    5
    This morning I did a descale of my Vivi and midway through I noticed that the boiler stopped refilling. The pump is still working and water is flowing from the tank and out the group head.
    The boiler heats up and hits its usual operating temperature.
    I think there is a solenoid somewhere for the boiler water level and probably a sensor too.
    Any tips on what I should try now?
    Any ideas about where I might find parts for this in Australia?
    It was bought from Bella Barista in the UK and I dont know in the MK 1s were imported here. I could give them a call and order some parts.
    Time to dust off the french press... no espresso this week I reckon. :-/
    Aug 2004
    2,312
    Re: Izzo Vivi MK 1: boiler level solenoid?
    What parts? No one knows that until they diagnose the problem, and you are talking electrickery.
    Best advice is take to nearest commercial esp machine service centre for diagnoses and repair. Theyre geared for diagnostics and repair of things that contain electrickery.
    Hope that helps.
    Site Sponsor
    Aug 2006
    1
    The importer of the mahines is Talk Coffee (Chris) he is one of the CS sponsors. However, most of this machines use common parts. You will be able to get this part probably from as or coffeeparts.
    Regards
    Renzo
    14,666
    Why did you descale? Did it need one? :-?
    I regret I have never seen inside a Mk 1, so its time for a trip to a techie who is prepared to work on your machine.
    Dec 2009
    5
    Thanks for the replies, problem solved. 8-)
    I removed and replaced the auto-fill probe and it worked again. Will keep a close eye on the machine to check it isnt an intermittent thing.
    Yep, it did need a descale, but I just saw your pinned thread with the tip about how to tell when which is something Ill do.
    I think the Mark Is are pretty much the same internally, the main change was to the steam arm.
    14,666
    Good to know espressomonkey,
    Glad youre up and running. Perhaps it might be worth looking at some filtration? The less you descale, the better. ;)
  1. Izzo Vivi - info/review needed
    By jtaus67 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 8th June 2012, 08:46 AM
  2. izzo vivi feedback vs the domobar junior
    By arcenite in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 29th May 2012, 09:03 PM
  3. Izzo Vivi PID or Vibiemme domobar jr dual boiler
    By Christian71 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 7th March 2012, 11:24 PM
