Results 1 to 8 of 8
Thread: Expobar minore III group pressure settings
    Senior Member NakiChap's Avatar
    Apr 2011
    Perth , WA , Australia
    352
    Hello CS`rs just after a bit of feedback from any minore owners regarding group pressure
    If the machine has been calibrated to give 9 bar at the puck, how many bars does the machines gauge show when doing a flush with the blind filter in ?
    Does 10 bar on the machines guage give approx 9 bar at the puck ?
    Thanks for reading :)
    Jan 2009
    162
    Re: Expobar minore III group pressure settings
    I dont think that there is going to be a precise answer.
    Best bet is to get someone with a Scace device to calibrate the pressure. This is going to give you a much more accurate result.
    The pressure is easily adjusted on the Expobar III. Rather than trying to "text book" calibrate the pressure why dont you do some experimentation to find out what pressure setting produces the best result in the cup!
    Apr 2011
    352
    Ok I all ready have my machine ajusted to where it suits me using the pullman pressure guage but I`m interested to see if there is a difference in the guage readings on machines that have been calibrated
    Jun 2009
    Surrey Hills VIC
    104
    Hi
    Im also interested in this.
    Should the group be set to 9 or 10.
    Or should I aim for a 9 when its actually brewing.
    They expobar actually comes from the factory with a 12 bar setting
    Would love your thoughts
    Apr 2011
    352
    Quote Originally Posted by 664355432C0 link=1335363616/3#3 date=1336618018
    Hi Joyo if you adjust your machine down to approx 10 bar from 12 bar factory setting you should see better results ;)
    Jun 2009
    Surrey Hills VIC
    104
    Quote Originally Posted by 7E5C595C533D0 link=1335363616/4#4 date=1336653691
    Hi Joyo if you adjust your machine down to approx 10 bar from 12 bar factory setting you should see better results* ;)
    Thanks Msta, thats helpful. Ill do that, saves me from playing around with it to find the right spot. Thanks
    Apr 2011
    352
    I have also been told that the factory setting of 12 bar is correct for a vibration pump and should be left at that setting
    Jun 2009
    Surrey Hills VIC
    104
    thanks again,
    i might give that a go and see how it tastes
  1. Low pressure on Expobar minore
    By Joyo in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 8th May 2012, 11:55 PM
  2. Expobar Minore 3 pressure
    By tangoandy in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 1st December 2010, 11:01 PM
