Results 1 to 13 of 13
Thread: Low pressure on Expobar minore
    Jun 2009
    Surrey Hills VIC
    104
    Hi all
    I just acquired the minore IV and would love so ke advice on why the group pressure reading is low
    Stays between 2-4 bars, and when running with blind in, it only goes to about 3.
    Ive tried to adjust the OPV but doesnt change it.
    Could something be loose?
    Thanks in advanced
    Jun 2009
    Surrey Hills VIC
    104
    Re: Low pressure on Expobar minore
    Also, just to add, the steam pressure looks ok, reads 1 bar.
    And the flow from the group seems quite weak.
    Love your wisdom
    Site Sponsor
    Aug 2006
    1
    Joyo;
    Take out the filter from the water tank, some times this filter does not allow the water to come through.
    otherwise look like is your pump is gone, take to your local teck, they will check all this for you.
    Regards
    Renzo
    Jun 2009
    Surrey Hills VIC
    104
    Wow that serious. A blown pump.
    Ill check the filter when I get home.
    Just wondering, How does a pump fail?
    Mar 2012
    42
    Over time mechanical parts do fail, how old is your unit?
    Though having said that I believe an OVP is meant to address the longevity of the pump (correct me if im wrong).
    Jun 2011
    84
    Do you know the history of the machine? How much use? correctly filtered water used? backflushed regularly? Does it need descaling? etc, etc. Is the group head gauge on the machine reading correctly? Can you check with an external pressure gauge on the group head.
    Jun 2009
    Surrey Hills VIC
    104
    Hi all
    Thanks for your help
    Its only a couple of months old, still under warranty.
    Its just beyond me what went wrong.
    Ill try to test it with a portafilter gauge.
    Mar 2012
    42
    When you purchased the machine did you get the person to make you a coffee or demonstrate that its working?
    Jun 2009
    Surrey Hills VIC
    104
    It was working fine
    So its beyond me.
    Mar 2012
    42
    Was this the one purchased off Mike Squires I had a laugh?
    Anyway, if youre that concerned you might better off bringing it to Chris at Talk Coffee for a look? Saves you the stress and gives you a piece of mind at least?
    Jun 2011
    84
    If its still under warranty, best not mess with it and just contact the reseller or distributor.
    Jun 2009
    Surrey Hills VIC
    104
    Yes thats the plan now
    Jun 2009
    Surrey Hills VIC
    104
    thanks all for your help.
    my noob mistake,
    preinfusion takes time, so the pressure doesnt rise until after a while.
  1. Expobar Minore 3 - low steam pressure
    By mote in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 26th March 2011, 11:13 AM
  2. Expobar Minore 3 pressure
    By tangoandy in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 1st December 2010, 11:01 PM
  3. Help! Expobar Minore pressure gauge
    By needmycoffee in forum Brewing Equipment (non-machine specific)
    Last Post: 23rd October 2006, 09:07 AM
