Results 1 to 2 of 2
Thread: Recommendation: Proper storage techniques for machine and grinder...
    Mar 2012
    42
    Hi fellow cs'ers,
    Going away in a month to the US for a secondment as part of work for 6 months. In this time the Giotto and Macap need to be stored away for the 6 months. Just wondering if there's anything I should do? empty the boiler and tank? or have someone flush it every so often?
    Any tips and guidance would be appreciated.
    Regards,
    Ron
    Dec 2006
    Perth WA
    572
    Not many replies!
    I put my Silvia into retirement and it revived okay.
    IMO
    Do a thorough clean, fill the boiler with fresh soft water. Not distilled water (corrosive) not hard water if you can avoid it.
    If you drain it all the seals and scale may dry out and cause problems later.
    Clean all the grinds out of the grinder.
    This worked for me. But I am not an expert.
    dumiya
  1. New grinder recommendation
    By drovers-sunrise in forum Grinders
    Last Post: 8th July 2012, 12:27 PM
  2. grinder recommendation.
    By lumenary in forum Grinders
    Last Post: 1st May 2012, 05:16 AM
  3. Help! I need a proper grinder!
    By gavin in forum Grinders
    Last Post: 17th December 2007, 05:33 PM
