Results 1 to 3 of 3
Thread: Isomac pressure problem
    Jul 2012
    Montreal, Canada
    1
    Question Isomac pressure problem
    A strange problem began today on my Millenium. Shortly after I started to pull my second shot of the morning the boiler pressure gauge climbed from the normal 1.2bar to the full max. I stopped the pump, the pressure came back down. Restarted the pump and again the same behaviour. It also seemed like less flow than usual was coming through the portafilter. Where to look for the cause of this problem? Can't imagine how the pump can cause the boiler pressure to rise/fall. Might the 2-way fill solenoid be leaking? Appreciate any feedback or suggestions.
    Apr 2008
    Victoria, Australia
    2,101
    pm sent..........
    Feb 2010
    46
    Sounds like your boiler inlet solenoid is leaking , will be pumping water into the boiler during extraction raising the pressure while starving the group.
  1. Adjusting the brew pressure (OPV) on Isomac Mondiale
    By hazbean in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 27th November 2014, 12:52 PM
  2. Isomac Tea Problem
    By GrahamH in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 10th November 2013, 11:13 AM
  3. Isomac Tea II Boiler Pressure
    By scollops in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 6th June 2010, 11:54 AM
  4. Isomac giadia problem
    By morningshot in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 13th February 2007, 01:34 AM
Tags for this Thread
