Results 1 to 6 of 6
Thread: Group head thermometer on my NS Musica - advice?
    Oct 2010
    146
    Hi,
    I'd like to install a thermometer on my Musica (HX). Its not an E-61. Any suggestions on where to buy the components and how to install one? Ideally I'd like to measure the brew water temp.
    Thanks.
    Apr 2012
    497
    The majority of groupheads have an instrumentation port of some type on them, usually an M6 port, as to the location on the Musica, I can't really advise as I'm not familiar with NS groups.
    There are a couple of places you can get adapters which will allow you to mount a thermocouple in the instrumentation port, pid silvia (non-sponsor) is the first one I recall off hand, then you connect it to a temperature display, I'd suggest using a cheap PID for temperature read-out (because they are generally cheaper than straight digital temperature read-outs, NFI why, presumably something to do with manufacturing volumes), ideally you want to find a T-Type thermocouple as they are more accurate than the (more readily available) K-Type thermocouples (+/- 1.0 deg C for the less accurate (there are two accuracy grades) T-types versus +/- 2.5 deg C for the most accurate K-types).
    Oct 2010
    146
    Thanks for the advice jbrewster.
    Has anyone made a similar mod before and can advise a good supplier for the components?
    Cheers.
    Jul 2007
    539
    I've done a similar mod to my Faema E98. Ordered parts from erics on the HB forum.
    Jun 2011
    684
    Just to clarify these tapped holes in groups rarely have anything to do with intended temperature or pressure monitoring - they are plugged holes left over from cross-drilling water channels through the solid brass castings. Using these ports for temp probes etc is a convenient afterthought.
    Not a Shoe Jimmytheboot's Avatar
    Jan 2009
    247
    Theres a thread on HB about doing this with an NS Oscar, which looks like the same group design, no 6mm port there so additional plumbing was required
  1. Group head Q?
    By liamo in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 25th December 2009, 07:00 PM
  2. Digital Thermometer & Adapter for E-61 Group
    By jimandlet in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 13th June 2009, 03:59 PM
  3. E-61 vs E-64 group head
    By Vicomte in forum Brewing Equipment (non-machine specific)
    Last Post: 1st April 2009, 10:22 PM
  4. Digital Thermometer E-61 Group
    By scott_ramage in forum Brewing Equipment (non-machine specific)
    Last Post: 28th November 2007, 11:16 PM
