Results 1 to 9 of 9
Thread: Anti-vac valve
    Senior Member skydragondave's Avatar
    Apr 2010
    105
    Anti-vac valve
    Does anyone know what material the anti-vac valve O-ring is made out of? Is this standard 70 durometer rubber, or is it neoprene? Mine has gone hard and is leaking.
    Also, should there not be a spring inside the valve to hold it against its seat? When I took it apart there was just the brass bell with o-ring behind it and it was just dangling loose agains the e-clip. The NS Appia parts book does not break down the valve and I'd rather just replace the 2 o-ring than wait for the valve to come in. Nothing wrong with the valve just needs a new o-ring and (possibly) spring.
    Thanks again
    Jul 2007
    2,288
    It is a high-temp rubber ring--and there is no spring. When there is no pressure in the tank the piston drops down. When the tank heats up, the force of the steam lifts the piston against the seal.
    Apr 2010
    105
    What upper-temperature limit should I be shooting for? I'm going to go in to a local MRO shop that specializes in bearings, seals and gaskets. Also, I heard about the Giotto machines having an updated antivac design that makes it more reliable. Would it be possible to interchange it with this one?
    14,665
    Not sure what you mean by upper temperature there? You may like to elaborate.
    The revised anti-vac goes back quite a few years now. We have been using this one which is a better quality all rounder. The bonus is that it's better quality and more reliable. It will also fit earlier giottos which didn't have the hole cutout in the cover plate under the top cover.
    Apr 2010
    105
    Hi,
    Just trying to determine what to ask for when I visit the MRO supplier on Monday. It could be a regular 70 or 90 durometer rubber O-ring, a silicone one, a neoprene one, it is black so Im pretty sure it isn't silicone though.
    By upper temperature I mean the highest temperature the o-ring would be exposed to. Thanks
    Aug 2010
    373
    You'll want a Viton O-ring, sizing (for most anti-vac valves ) is 007 (5/32" nominal internal diameter).
    Feb 2005
    3,098
    In my Grimac the o-ring some time ago made the piston stick. I simply dug into my collection of various size o-rings for all purposes and found one which fit.
    Jan 2010
    131
    Do you change anti vac valves as preventative maintenance or wait for it to go wrong. Thanks in advance for any replies.
    Feb 2005
    3,098
    Quote Originally Posted by adjiland View Post
    The machine will tell you when the valve needs attention. Perhaps a clean o,r fine emery cloth polish of the cylinder or a new o-ring.
  1. anti vac on ecm giotto
    By JohnA in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 18th October 2011, 11:37 PM
  2. Sticky La Cimbali Anti-Vacuum Valve
    By GCM58 in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 27th September 2011, 09:18 PM
  3. swapping out an anti-vac valve on VBM Super
    By Viscera in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st July 2010, 07:06 PM
  4. Anti Suction Valve Leak
    By ento in forum Brewing Equipment (non-machine specific)
    Last Post: 30th January 2009, 01:02 PM
  5. Giotto problem - anti vacuum valve?
    By beetle in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 3rd December 2008, 12:43 PM
