Results 1 to 9 of 9
Like Tree7Likes
  • 1 Post By Vinitasse
  • 2 Post By GreenBeanGenii
  • 4 Post By noidle22
Thread: Small screw found inside steam wand of Rancilio Z11! WTF!?
    Senior Member Vinitasse's Avatar
    Aug 2010
    Mornington Peninsula VIC
    1,251
    Hi there,
    Customers of mine with an ancient Rancilio Z11 complained that their steam wand pressure was way down so I decided to go in and take a look at it... assuming that it merely needed cleaning. However, when I removed the steam wand tip I found a tiny screw inside. Took it out... reassembled everything and the steam pressure was back up where it should have been.
    The question is, where the hell did the screw come from?
    Any ideas???
    sprezzatura likes this.
    Aug 2007
    163
    If that was from my home, then I would nominate the SO/husband as fiddling where he knew he should NOT tread.
    Vinitasse and sprezzatura like this.
    Mar 2012
    Bathurst
    1,228
    Probably tried to block one of the steam tip holes but somehow pushed the screw up in there, maybe they didn't know the tip could be removed.
    Some of the things you see on customers machines makes you wonder how society even manages to function at all.
    Aug 2007
    163
    Quote Originally Posted by noidle22 View Post
    Giggles here. Many belong to the genre that never ever make use of an instruction manual.
    Jul 2011
    Hobart
    346
    The parts list/diagrams are useful. However, the 'instructions' in machine manuals are often pretty sh*thouse at best if not just plain wrong...
    I've had the tiny screw work its way out of my specs - which is no big deal until an arm falls off... Or perhaps the screw has worked its way from the water tank into the boiler!
    Senior Member sprezzatura's Avatar
    Dec 2013
    Toogoom, QLD
    931
    I agree with noidle - rudimentary steam control. Sometimes toothpicks get stuffed up in one or two of the holes.
    Dec 2013
    Toogoom, QLD
    931
    Wait until you see a fuse protected PCB with a wire jumper soldered in
    Mar 2012
    Bathurst
    1,228
    I've seen a bullet casing and also a coin used as fuses.
    To be fair it wasn't a live bullet so that's at least one of the safety concerns covered.
    Aug 2007
    163
    Not coffee machine related but similar
    SO went to a rental property because the tenants had complained about their GAS room heater. He did freak when he found the room heater to be installed with garden hose and dodgy fittings. To cover himself, he actually disconnected the gas meter. Hard to deal with stupid.
