Results 1 to 28 of 28
Like Tree6Likes
  • 1 Post By Dimal
  • 1 Post By artman
  • 2 Post By artman
  • 1 Post By Hadrami
  • 1 Post By Dimal
Thread: Problem with brewing pressure - ECM Technika IV Profi
    Aug 2013
    23
    Not sure if this is in the right category so mods please feel free to amend.
    I have a 2 year old ECM Technika IV Profi and the brewing pressure has dropped down to 6. I have tried to manually adjust it but no success. It is also intermittently cutting off.
    And ideas?
    Thanks.
    17,457
    G'day mate...
    Probably would have been better placed in the "Pointy End" machines category....
    What happens if you grind fine enough to choke the machine; pressure still low?
    sprezzatura likes this.
    Aug 2013
    23
    Haven't tried that but I did a backflush but pressure still wouldn't go past 6.
    Senior Member sprezzatura's Avatar
    Dec 2013
    Toogoom, QLD
    931
    When you say manually adjust you mean you've increased resistance on the over pressure relief valve, yes?
    Aug 2013
    23
    Quote Originally Posted by sprezzatura View Post
    I'm not too familiar with all the correct terms but see the screw right under the water tank, I've turned that clockwise all the way.
    Dec 2013
    Toogoom, QLD
    931
    That's correct. Did the pressure come up at all?
    Dec 2013
    Toogoom, QLD
    931
    Also, try placing your blind (cleaning) basket in the group handle and engage the pump: does water discharge through the clear silicone tube connected to the brass valve below the screw we're talking about? It returns water to the reservoir (tank).
    Aug 2013
    23
    No, stayed the same at 6.
    Aug 2013
    23
    Checked that as well, and it seems to be functioning properly. Still brewing at 6 bars and there doesn't seem to be any loss of water.
    Dec 2013
    Toogoom, QLD
    931
    My guess, if the screw on the bypass valve is in all the way clockwise (least water bypass) and your pump is operating nominally then you may have a faulty OPV (over pressure relief valve - which regulates reciprocating pump pressure). Other culprits can be: faulty pressure gauge; obstruction downstream from OPV which may be in the group head itself.
    Unless you're keen to start disassembling your group to trouble-shoot further it may be a good time to take it in for a service.
    Dec 2013
    Toogoom, QLD
    931
    There is the intermittent power issue you mentioned as well. This can be any one of (probably) 3 things electrical which requires electrical fault diagnosis. Unless you're electrical it's better to have a machine tech trouble-shoot it for you.
    I used my last machine @ 4.5 and 6bar. It was pretty happy there. Grind fine and tamp light until you can find a good service centre (there are plenty here - see Sponsors).
    Matthew
    Dec 2013
    Toogoom, QLD
    931
    Gosh! I missed something! The Profi has a rotary pump in the rear. You may need to adjust the bypass on the rotary pump.
    Here is an image. The adjustment is on the right in the image (not mine) which is on the pump. The other (on the left) is the OPV on this model.
    You will need to remove the cowling to get to the rotary pump. You will know if you have a rotary pump because the machine won't sound like a miniature jack-hammer when you're extracting a shot.
    Same rule applies: clockwise to increase pressure.ImageUploadedByTapatalk1451193306.640510.jpg
    Senior Member artman's Avatar
    Jun 2006
    2,471
    If adjusting the bypass (which normally has a lock nut) does nothing to the crew pressure (check with a blind) then it's possible the piston inside the bypass is stuck and not moving. This happened on my machine (Faema) and I unscrewed the bypass from the pump head, cleaned it up, relubed and all was well.
    If you adjust your brew pressure to 10 bar with a blind it will be about 9 bar with a brew flow.
    You want to adjust the OPV to 12 bar. It's there so if the pump pressure goes very high the OPV will bleed off the excess as a safety fail safe. You can test it by ramping up the pressure on the pump and seeing when it starts bypassing.
    Dec 2013
    Toogoom, QLD
    931
    Definitely - the bypass piston is a culprit. You can back it off a full turn and advance it the same several times which can free the piston (sometime the o ring on the piston can stick after a period of non-use).
    Jun 2006
    2,471
    Yep that's what was wrong with mine. No amount of turning the screw would free it. On my pump head the entire piston housing could easily be unscrewed and everything cleaned and lubed. It is just a piston with a seal and a spring behind it to provide the adjustable pre load. I posted a thread on it here a while ago it's pics.
    Should be an easy fix.
    kranked and sprezzatura like this.
    Aug 2013
    23
    Thanks guys, I'll give that a go and report back.
    17,457
    Something I also noticed from your photo in the opening post, is that there appears to be lot of detritus in the water tank.
    If this is the case, maybe your water filter options are not working well, and some of this 'grit' is finding its way into parts of the hydraulic circuit that it shouldn't.
    Please disregard if this is not the case...
    Aug 2013
    23
    Ok so I finally got a chance to open up the machine, but am not sure what I am looking for? I placed the water tank up the top to get a clear shot.
    Aug 2013
    23
    Any ideas?
    Jun 2006
    2,471
    Yours has a vibe pump, not rotary. Hard to see without being able to follow the piping but the valve near the tank looks to be the pressure adjuster.
    Do you see any change in pressure using a blind when this is adjusted? Is there any water bypassing out of the plastic hose?
    Aug 2013
    23
    I've turned that as much as possible and tightened one of the bolts and managed to get it back up to 7 bars, that's all. Checked all the plastic hoses and there doesn't seem to be any leakages.
    Thanks.
    Aug 2013
    23
    Any other advise guys?
  23. #23
    May 2014
    Brisbane
    279
    If nothing is working, I'd book in a service to get it sorted.
  24. #24
    Senior Member readeral's Avatar
    Jul 2015
    1,091
    If you do get it serviced, would love to know the outcome. I have one of these machines, and as much as I hope it won't break down, would be good to know if there are any things to look out for.
    Have you considered that it might be scale?
  25. #25
    Aug 2013
    23
    Still using it at 7 bars. Noob question but is descaling same as back flush?
  26. #26
    Dec 2006
    Perth WA
    572
    No! Back flush is removing the espresso coffee deposits. Descale is removing the boiling water deposits in the boiler. Very different areas and chemicals!
  27. #27
    Jun 2006
    2,471
    Are you getting water flowing out of the hose if using the blind?
    This would indicate you are bleeding pressure and the OPV might be the issue.
    If no flow then it might be your pump not producing enough pressure.
    Aug 2010
    45
    FWIW I had same problem.
    Turned out pump was in slow decline.
    Replaced pump and now back at 9-10 pressure.
