Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By flynnaus
Thread: Rocket Giotto pressure problem
    Sep 2012
    76
    Hi there. I need some advice re Rocket Giotto . This morning I turned the machine on , heated up fine but there's no boiler pressure. Turning the machine on and off didn't do anything. Any suggestions please.
    Nelson
    Dec 2011
    PRL
    2,770
    Not 100% sure what 'heated up fine by there's no boiler pressure' means (i.e. there's no steam? or the gauge just isn't moving or what?) Could be false pressure if valve is sticking. Try opening the steam valve, letting any steam out, then (leaving steam valve fully open) turn off, turn back on again 15 or more minutes later. Someone else will have a better idea than me.
    Dec 2006
    Perth WA
    572
    Experts will chip in.
    You believe the boiler did heat up? You presume there was water in the boiler? Did you get hot brew water when you lifted the extraction lever. That would prove the boiler did heat up. If it did I expect it was the anti vac valve not releasing the vacuum in the boiler which was created when the boiler cooled from last use - I don't quite understand this. If it was cold then it suggests the switches in the module are faulty.
    Sep 2012
    76
    yes sorry my bad, the machine is warm,but not up to operating temp
    Sep 2012
    76
    yes there was warm water from head when I lifted extraction lever. no steam, no water out of tap.
    May 2008
    4,212
    It might be something as simple as a dodgy pressure stat but it requires qualified diagnosis. If it was my machine I would be talking it to a skilled coffee machine technician and consider it getting serviced professionally while it's there.
    Sep 2012
    76
    ok, so I just turned the machine on with the steam valve and water tap open. It actually made pressure. it's working fine ATM . I can hear the odd hiss though. is that the anti vac valve ??
    Dec 2011
    PRL
    2,770
    Quote Originally Posted by kike10 View Post
    Sounds like it (i.e. sounds like the problem this time was a sticking valve). Not sure about the hiss....could be the pressurestat. Probably time for a service when you can book it in. One of the experts will undoubtedly see this and comment.
    Sep 2012
    76
    thanks all for your quick response. Hopefully it's just a sticky valve .
    May 2008
    4,212
    Yep. The hiss is the anti vac valve. I'd still be taking it in for a service but I wouldn't be surprised if the antivac is replaced (it only costs about $13).
    Dimal likes this.
