Results 1 to 12 of 12
Thread: ecm giotto problem
    Apr 2007
    403
    ecm giotto problem
    I was just backflushing my giotto when all of a sudden something went wrong.
    I get no water coming out of the group head now and it also seems the pump may have died as when i normaly works its loud but now i only hear a slight noise when its running, or trying to run.
    Any tips? or how do i know for sure its the pump?
    Senior Member Dennis's Avatar
    Feb 2007
    4,513
    Re: ecm giotto problem
    No offense meant John, but did you check the water level and that the reservoir is in place correctly?
    Apr 2007
    403
    Dennis, no offense taken mate
    yes checked the reservoir and it was still 3/4 full and sitting in place correctly.
    I pulled it out and put it back in place to be 100% sure.
    Feb 2007
    4,513
    John, if you happen to live in Sydney I recommend you give Di Bartoli a call and speak with Renzo. If youre in Melbourne then 2mcms your man.
    Apr 2007
    403
    i think i have a poltegeist at home.
    Turned the machine off after it happend.
    Let it cool down and just went to take the top pannel off to have a look inside for any obvious faults.
    Not that i knew what i was looking for, but just incase a hose come off or something.
    Couldnt find anything, so put the lid back on, put the water reservoir back in, fired it up and guess what.
    Yep the pump started working as per normal.
    Maybe she had a hissy fit :)
    Thanks for the help though Dennis, and yes, if it happens again, i think it will be going straight to 2mcm for a service
    14,666
    Hi John,
    A few things can cause this....Give me a buzz if you want to discuss...
    regards
    Apr 2007
    403
    Thank you Chris
    will give you a call tomorrow morning
    Jun 2006
    BRISBANE
    2,001
    Given that some of us pine after big shiny expensive machines...can the "few things that can cause this" be summarised on the forum...I (and I guess other too) am building up a store of info about these high end machines...so when the time comes to upgrade I know a bit more about whats what.
    CHEERS
    14,666
    Quote Originally Posted by ozscott link=1181123403/0#7 date=1181182880
    CHEERS
    Scott- It is normally too clean or too dirty water. Distilled or over filtered water has little ionic content = no conductivity and machine thinks its empty= Safety cutout to protect the element. If grotty water coats the tank probe with scale or causes oxidation, same problem. RO water causes the same issues if not modified ala Veneziano style. RO unmodified = Machine Killer...
    A heap of flusing of both HX and boiler is required after descale as residual gunk can be found pretty much everywhere and this can lead to gremlins.
    We recommend only filtered, softened water in all of our machines- so descaling should be pretty much unneccessary....
    Apr 2007
    403
    once again thanks for all your help Chris
    ozscott, have no fear in purchasing these machines. In over 3 years, appart from this and another incident which was totaly my fault, i have had no major issues. They are bullit proof.
    When the time comes and the ecm goes to coffee heaven (which shouldnt happen for a very long time) i wouldnt hesitate to purchase another one
    Jun 2006
    BRISBANE
    2,001
    thanks very much gents....again great forum
    Bon
    Bon is offline
    Nov 2006
    173
    ^^ I agree, my ECM is solid as a rock.
  1. After service problem - Giotto
    By norden in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 19th August 2011, 10:36 PM
  2. ECM Giotto Problem
    By venno in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 29th April 2010, 01:26 PM
  3. Giotto Problem
    By farmroast in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 20th March 2009, 12:09 AM
  4. Problem with Giotto
    By bolb in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 6th April 2007, 01:30 PM
