Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By trentski
Thread: HX machine boiler water refil
    Sep 2011
    20
    Hi,
    I just got a Bezzera BZ10, wondering when the water refills in the boiler?
    When I use hot water or extract from the group, does it refill automatically or does it need to reach a certain level before refilling?
    16,955
    Quote Originally Posted by Jbounce View Post
    G'day mate...
    Is this a new machine or a 2nd-Hand one?
    If new, you first port of call should be the vendor from whom you purchased the machine...
    If everything is working normally, the Boiler Water Refill is Automatic. You will hear the pump run even when you're not pulling a shot or dispensing Hot Water...
    Nov 2009
    Altona, Melbourne
    1,581
    Often you'll hear the pump run just after you turn it on from cold. That's the boiler refilling.
    Of you run some hot water out the tap you'll hear the pump run to fill the boiler.
    kbc likes this.
