Results 1 to 4 of 4
Thread: Frustrating channelling problem - Breville Oracle
    Sep 2006
    22
    Greetings folks
    I have 2 oracle machines - 1 for work and another at home
    The work machine has developed a frustrating channelling issue - it extracts fine after pre-infusion then blonds and runs watery (at 11 sec overall)
    All settings are identical - temp, pre-infusion time etc
    Beans are fine - perfect extraction in home machine
    Puck from channelled extraction looks similar however is dry in the middle - changed baskets between 2 machines but problem persists
    Have fiddled with the grind with no success, backflushed to make sure screen is clean
    Auto tamp seems ok - (2 machines are in separate locations so can't really confirm tamp from one to the other)
    Actually manual tamped to see if that made a difference with no success
    Dose seems the same with both machines (haven't weighed however)
    Any suggestions ??
    Dec 2004
    Earth!
    15,747
    Were the beans brewed at home brought home from work and brewed the same day? If not try doing some that way and see how they brew.
    Java "The devil is in the details" phile
    Toys! I must have new toys!!!
    Senior Member Lukemc's Avatar
    Oct 2012
    MILLBROOK VIC
    698
    Drop the screen and clean behind it if you havenít already. Maybe an issue there with a part of it blocked forcing water thru a smaller area?
    Apr 2013
    7
    I also have two Oracles, one at work and one at home, and while I haven't had your exact issue the home machine is much more temperamental than the work one. Is it just you using it? There's not much you can do to these machines I don't think in terms of abuse but are other staff etc using it?
