Results 1 to 5 of 5
Thread: Nuova Simonelli Musica - Water level sensor not working
    Jan 2016
    3
    Question Nuova Simonelli Musica - Water level sensor not working
    Hello All,
    Is there anyway that I can fix this myself as I am a very handy person.
    The water level sensor isn't working, it doesn't activate the low water level warning light even when water is at its lowest level, I noticed this when the pump becomes really loud when it tried to suck water from empty tank. I can see that there is a magnet in the water tank itself and it is moving freely, that mechanism is working fine. How do I fix this issue? And in addition, it seems that the volumetric isn't working too.... it just dispenses unlimited amount of water through the portafilter no matter what volumetric button I press.....
    Jun 2018
    625
    The switch (probably a reed switch) is called out as item 2 on page 75 of the Manual
    Nov 2017
    Maddington, Perth. Wa
    1,072
    Mine doesn't work either. I haven't tried to fix it yet though. I just check the water level more often
    Jan 2016
    3
    Quote Originally Posted by Lyrebird View Post
    I wonder if anyone has the service manual?
    Jan 2016
    3
    check this out:
    https://www.coffeeparts.com.au/parts...uova-simonelli
    I wonder what parts we need
