Hi all.
I can't find an answer to this on a previous thread.
I have a Boema classic single group machine.
I am having flow issues.
Currently connected to a 15l container about 1.5m above the machine. The machine will prime on initial start up of the machine but will not redraw. When machine is up to temp I get a small ammount of water through the group head then it stops. The pump is running during this.
I also have the same problem with the hot water. It just seems to empty what is in the boiler and does not redraw. I have checked and cleaned all pipes and can blow air through them. The group head has been disassembled and cleaned.
I did hook the machine up to my outside hose to test and it ran fine. Continuous flow from both hot water and group head.
Any assistance on diagnosis would be great.
