Results 1 to 5 of 5
Like Tree4Likes
  • 2 Post By Barry O'Speedwagon
  • 2 Post By Lyrebird
Thread: Pump not working autofill
    Nov 2017
    12
    Hi,
    I am trying to get an 1987 vibiemme to work.
    When the waterlevel is too low:The pump doesnt engage. The water level sensor (rod) is clean. The solenoid/one way valve opens up.
    The pump itself works during brewing.
    It might be the gicar control box (autofill type). How can I check this?DSC_0959[1].jpgDSC_0960[1].jpg
    Thanks for pointing me in the right direction.
    Best regards, Willem
    Dec 2011
    PRL
    2,574
    Try playing 'We Built This City' while working?
    Dimal and 338 like this.
    Jun 2018
    423
    Disconnect the wire from spade 4* on the controller and short the spade to ground using a test lead. If the pump runs the fault is in the wiring. If the pump does not run the fault is in the controller.
    * Double check that spade 4 is the level control, it looks to be but I'm not familiar with that particular controller.
    Nov 2017
    12
    Tried the song. Unfortuntely no luck.
    The grounding wire method is the other way around. Grounding on spade 4 should stop the pump. Tried that already, the pump won't start. So which terminal on the controller box triggers the pump?
    Jun 2018
    423
    Yes I wrote that the wrong way around, of course grounding the spade is the "full" signal. Sorry for the confusion.
    There is no single answer to your question as the pump relay is controlled by the microcontroller. If you can follow the traces on the PCB you can do some testing but the fact that the pump works when pulling a shot makes it likely that the uc is playing up.
Tags for this Thread
