Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By Jackster
  • 1 Post By aliel
Thread: Rocket Evo pump switch adjustment help
    Mar 2015
    19
    Hi,
    I've had my rocket Giotto Evo coming onto 5 years now and i've noticed that the pump switch roller has moved slightly off centre.
    Now whilst it doesn't directly affect the machines performance the misalignment is starting to scratch the part of the lever it contacts.
    I was hoping someone could assist me with this or point me to the correct thread for how to adjust it.
    I have attached photos below for reference.
    Nov 2017
    Maddington, Perth. Wa
    1,107
    Loosen locknut, twist back straight and tighten back up. Might need some masking tape on stainless so you don't scratch it. Or use the locknut if you can access it.
    Unplug from power before pulling any covers off machine
    Dimal likes this.
    17,564
    Yep, just remove the Lever first and then a deep socket to access the locknut to avoid scratching the front panel...
    Easy peasy.
    Mar 2015
    19
    Thanks so much guys!
    Dimal likes this.
