Results 1 to 4 of 4
Thread: VBM hot water taste
    Sep 2006
    20
    VBM hot water taste
    Hi,
    The water which comes out of the VBM hot water spout has a "taste" about it. You get a hint of it with plain water that comes out of the group head, but its nowhere near as noticeable and it doesnt impact my espressos.
    Is it just because the machine is new? Or is the water, or something in it, reacting with the heat?
    Sep 2006
    20
    Re: VBM hot water taste
    I spoke with Ofra at Di Bartoli and she suggested to give it a good flush and to make that part of normal routine. She also suggested to use filtered water like a Britta system, which I had already started to use. It is now better than it was with just a hint of the taste still remaining.
    Id still be interested to hear if others with a dedicated hot water sport have noticed similar?
    14,665
    Quote Originally Posted by lyds link=1194936593/0#1 date=1195169364
    Hi Lyds,
    Unless youre turning good volumes of water over each day, some metal taint is a given. Given a 2.7L boiler, you effectively have about 1.3L of water sitting hot in a metal container all the time whilst the machine is on. Its impossible for there not to be some leaching of metal ions into the water...
    Filtered, softened water is a very desirable thing in any machine. Just dont forget to replace the cartridges in your jug as per the instructions.
    Feb 2006
    459
    Havent noticed any taste in mine, but thats a relative thing to Auckland tap water... (I filter it to go through the boiler though)
  1. Bottled Water - Perth Area, very hard water.
    By dskilton in forum Brewing Equipment (non-machine specific)
    Last Post: 15th May 2012, 12:24 PM
  2. Maintenance of water softener/filter on end of water intake pipe
    By andrew in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st March 2011, 12:53 AM
  3. Question about drawing water now that I have replaced the in tank water softner
    By barrel in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 24th August 2009, 09:43 PM
  4. Rubbery taste in steam and hot water
    By nsandison in forum General Coffee Related...
    Last Post: 14th November 2008, 03:12 PM
