Results 1 to 8 of 8
Thread: Water spill in VBM Domobar
    Sep 2006
    20
    Hi folks,
    I was filling my VBM with water when the lid came off the water jug. A good deal of water spilt inside the machine. :(
    I am hoping these things are built for such events, are they?
    10,496
    Re: Water spill in VBM Domobar
    My Expobar has drain holes in the back corners (either that or its poor bloody Spanish workmanship ;D ).
    Try tilting it back a little and seeing if that helps.
    Sep 2006
    20
    the water came out alright.
    It was just that it poured all thru the perforated casing into the guts of it. Id be surprised if the design of it didnt allow for that happening given its a wet environment. (pray, pray, pray).
    17,209
    Gday lyds,
    Dont know who you bought the machine from but Id give your vendor a quick phone call to ensure that nothing is done that might VOID your warranty..... :o
    Best to be careful,
    14,665
    Quote Originally Posted by lyds link=1207140152/0#0 date=1207140152
    Hi folks,
    I was filling my VBM with water when the lid came off the water jug. A good deal of water spilt inside the machine. *:(
    I think youll be ok Lyds,
    The major bits are well protected....Id tip it up to allow the majority to drain away and then leave it on for a while to dry off....
    Sep 2006
    20
    thanks for the advice guys
    Senior Member tasadam's Avatar
    Dec 2006
    Near Devonport, Tasmania
    278
    I was just having a read of something and it reminded me of this post so I thought I had better share.
    Taken from http://www.1st-line.com/machines/comm_mod/esprmach/vibiemme/index.htm#machines
    The bottomline is that microswitches do work the best, and the Vibiemme Domobar Super has the most industrial microswitch we have seen to date in semi-commercial machines. Some people will complain they fail, and this is true when you pour water on a microswitch. So, do not get water on them.
    So next time you are in there it may pay to look at the microswitch and see if it looks like it got wet. Or talk to Chris as he is the local guru.
    Switches cant cost THAT much, so you might want to replace it anyhow, for peace of mind. Not a problem if you never run out of water, but...
    14,665
    Quote Originally Posted by tasadam link=1207140152/0#6 date=1207783930
    No need to worry anout the microswitch IMHO. It sits under the tank support which is on springs. I reckon you could pour 10L of water down (which I wouldnt recommend ;)) and youd still have no chance of wetting the microswtich.
  1. Maintenance of water softener/filter on end of water intake pipe
    By andrew in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st March 2011, 12:53 AM
  2. How BP would handle a coffee spill
    By A_M in forum Off Topic
    Last Post: 25th July 2010, 05:33 PM
  3. Question about drawing water now that I have replaced the in tank water softner
    By barrel in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 24th August 2009, 09:43 PM
  4. Spill the beans?
    By Dimal in forum General Coffee Related...
    Last Post: 20th October 2008, 11:33 PM
