Results 1 to 6 of 6
Thread: ECM Rocket / Giotto Pressure Loss
    srm
    srm is offline
    Oct 2006
    6
    Hi
    We have a ECM Rocket / Giotto that is not holding pressure. If machine is left on pressure falls to zero bar - after you switch on and off it returns to normal pressure but only for one or two coffees. Has anyone else experienced this or have solution? Machine is only 18 months old.
    3,498
    Re: ECM Rocket / Giotto Pressure Loss
    srm,
    My guess is you have a sticky pressurestat (not an uncommon problem by the sounds of it)..... however unlike some which stick in the on position (and just keeps boiling and boiling)..... yours switches off..... and stays that way.
    When the unit is turned off and cools the pressurestat starts to work again.... but after a couple of cycles sticks in the off position once more!
    Sounds like a replacement is called for.
    srm
    srm is offline
    Oct 2006
    6
    Hi JavaB
    Thanks for the reply - is this something costly and as an aside how frequently should a machine be serviced. Current usage is only 2 coffees a day.
    Apr 2008
    8
    I had this 2 yrs ago. Does the machine still operate when the gauge shows no pressure? Ours did this and I suspected (and someone in this thread also mentioned) the pressure gauge needed replacement. A servicing proved this to be the case. I dont remember the cost but cant remember it being outrageous as it was fixed as part of the servicing which including other minor parts (gaskets, etc) and was about $150.
    Re servicing interval. We were told every 12mths but I do it about every 18mth or if things are not quite right. Having had one of these machines for a few years now I do think it is worth servicing regularly and have noticed a difference in shot and steam quality each time.
    Even if you only make a couple of shots a day, the time it is on can impact on things like the gaskets which are cheap to replace.
    Sep 2004
    136
    I noticed a one-off pressure loss this morning - the machine heated up for 20+ mins and reached the nominal 1.25 bar. I then drew a good 500+mL hot water, and it dropped back to zero. Out of interest I tried the steam nozzle - zip, nada. It all recovered after a while, but it surprised me that it dropped off like this.
    14,665
    Quote Originally Posted by DavidR link=1211009527/0#4 date=1217717363
    Anti-vac valve David...
    Time to replace it ;)
  1. Pressure(?) problem with Rocket Giotto
    By shiny in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 12th December 2012, 03:18 PM
  2. New Giotto Rocket pressure problem
    By pmcolli1968 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 31st August 2011, 03:04 AM
  3. Rocket Giotto steam pressure dropping
    By Flo in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 23rd February 2010, 07:37 AM
  4. [m]: ECM Rocket / Giotto Pressure Loss
    By TC in forum Brewing Equipment (non-machine specific)
    Last Post: 17th May 2008, 05:32 PM
