Results 1 to 5 of 5
Thread: ecm giotto premium - something went wrong
    Apr 2007
    415
    As usual my giotto gets turned on in the morning and stays on all day until bedtime.
    Today, i had my morning coffee and had to go out for a couple of hours.
    When i got home, the garage door wouldnt open, hmmm strange, maybe power failure Nope, there was power.
    Went in through the front door, into the garage, (NOT paying any attention in the kitchen at this point) and found the safety switch for power had tripped.
    hmmm odd i though, ah well, i need a coffee, but damn have to wait for it to reach temperature again. As i walked into the kitchen towards the coffee machine, i see water all over the bench and on the floor.......
    water reservoir completely empty, it was full, and only 1 coffee made
    so wondering what the cause to this may have been, has never happened before, but now i am tempted to turn the machine off if i go out for a little while
    14,665
    Re: ecm giotto premium - something went wrong
    Quote Originally Posted by JohnA link=1216609295/0#0 date=1216609295
    Does the fault still exist?
    Maybe just a leak?
    or....
    1. Pressuretat fails leading to over pressure
    2. Breaker valve blows off- leading to water everywhere (walls too?)
    3. Machine continues filling until no more water and then overtemp cutout trips, taking your safety switch with it?
    Apr 2007
    415
    water seemed to be just on the benchtop and floor.
    i dare say it was option 3 except it didnt trip out, only took the safety switch.
    i filled the water tank again, fired it up and is working as per normal now.
    I purposefully opened the hot water tap to empty out part of the boiler, just to check it stops when filling, rather then overfilling. This seems to work fine also.
    Will keep an eye on it though
    As for pressure, it sits nicely at 1 bar
    Aug 2008
    1
    Make sure you keep a VERY close watch on this one. I have had an ECM Giotto premium for almost 4 years now, and have had my 3rd pressurestat failure this past weekend where the machine almost melted itself down. The pressurestat rarely fails all out...it will at times fail to cut out pressurizing the machine, and then work perfectly for another 20 times. From my experience, the pressurestat in the Giotto is incredibly failure prone. I am now upgrading mine to a CEMA pressurestat, with a Jaeger pressurestat kept in the cupboard as a plan B...
    The pressurestats that have failed after initial failure were a bit unknown to me as I had this serviced at a commercial espresso repair facility. I am now going to do my own servicing.
    Please watch your unit and do NOT leave it on unattended.
    Apr 2007
    415
    thanks for the reply.
    It hasnt happened again since that time, but now i do switch the machine off if not going to be home for sometime.
  1. question - Giotto PP or giotto premium?
    By cafe_lover in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 30th January 2010, 12:16 PM
  2. Giotto Premium vs Giotto Premium Plus
    By Wayne_Gifford in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st June 2009, 08:06 PM
  3. Differnce between Giotto Premium and Premium plus
    By patto21 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 1st February 2009, 07:59 PM
  4. The New Giotto Premium Plus
    By DiBort in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 15th August 2008, 04:02 PM
  5. ECM Giotto Premium
    By Jimbo in forum Brewing Equipment (non-machine specific)
    Last Post: 24th July 2006, 01:15 PM
