Results 1 to 6 of 6
Thread: Boiler water....
    Mar 2008
    437
    Boiler water....
    In the past say....1.5-2 months I have not drained a drop of water from my boiler (ie use the hot water tap).
    Then this morning, I used it to warm a cup up and noticed the water was brown.....
    Rust perhaps? water too clean?
    DONT USE
    Jan 2008
    432
    Re: Boiler water....
    hi gavin
    i take it you have a hx machine
    water has become stagnant
    flush hot water through hot water spout until it clears
    this might take awhile as machine needs to recover at intervals
    after water clears, check for any offensive smell or taste
    if smells, descal required
    advised to take atleast 500 ml from hot water spout weekly
    graham
    Apr 2007
    1,687
    I routine ive gotten into is dumping the hot water from the steam boiler (its connected to the hot water tap) into a jug. Thats the water I use to soak my PF over night with the machine cleaner (cafetto) in it. It keeps the water in the steam boiler replanished and not go stale in case someone wants a long black that doesnt taste like waste.
    May 2008
    600
    I dont know what most people do, b ut I drain my boiler each week using the drain plug. I also flush about 1ltr through each group at the same time. Im sure it probbly isnt required, but habit.
    Mar 2008
    437
    thanks for your help guys.
    Boiler flushed...
    Dec 2005
    260
    I also have this problem. With pressure in the machine, I turn it off then open the hot water tap till the boiler is empty (draining it near completely I assume). I then turn the power on so it would refill, then repeated the process 3 or 4 times. The water out of the boiler still tastes metallic.
    Ive only had the machine a couple months, and even though the water here (Illawarra) is incredibly soft from the dam, I still run it through a brita softner - my last machine didnt accumulate any noticeable scale after a year of use so I cant imagine I suddenly have a scale problem now.
    Nevertheless I will descale it soon - its a bit more involved with an HX, so Ill have to get really motivated one day :) - and see if it makes much difference.
  1. Boiler water level probe
    By JohnA in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st June 2013, 05:56 PM
  2. Boiler pressure as water temperature
    By Andy-Gadget in forum Brewing Equipment (non-machine specific)
    Last Post: 18th March 2010, 05:47 PM
  3. HX Boiler Pressure verses Group Water temperature
    By dumiya in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 27th February 2010, 11:27 AM
  4. Rancilio S26 -Boiler Water Level
    By Sacred_Cow in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 26th October 2009, 08:30 PM
  5. Clean water for boiler unit
    By jprm in forum General Coffee Related...
    Last Post: 9th May 2009, 10:52 PM
