Results 1 to 4 of 4
Thread: correct coffee & water mix for french press
    Senior Member summercrema's Avatar
    Mar 2008
    266
    Hi,
    need some help here, what is the correct mix for coffee & water when using french press to make coffee for 1 to 2 person. I have a solis grinder & a 3 cup French press just to get me by for this month.
    I think the grind size should be much bigger than for espresso & water temp somewhere between 92 - 94 degree celsius, I let it rest for 4 -5 minutes without stirring it , am I correct?
    I have tried using 14g of El Salvador coffee beans per 300ml of water but the taste is rather weak .
    any suggestion would help. Thanks
    Sep 2008
    759
    Re: correct coffee & water mix for french press
    Hi Summercrema,
    Luca posted a link to a great video about brewing for plunger a little while back.
    http://www.squaremileblog.com/2008/11/12/videocast-2-french-press-technique/
    Jul 2008
    Port Fairy
    2,993
    For me I grind fairly fine at about white sugar consistancy while I have seen others grinding (comercially) at more like raw sugar size. My preference is finer grind 2-3 minutes and 6g/100g (approx). Finer grinds more (and nicer) flavour in less time but a little sludge in the bottom of the cup.
    try these few links and the new manual brewer section
    http://coffeesnobs.com.au/YaBB.pl?num=1186754466
    http://coffeesnobs.com.au/YaBB.pl?num=1185713780
    http://coffeesnobs.com.au/YaBB.pl?num=1180916914
    Nov 2007
    BRISBANE
    201
    I normally use 14g of beans to make 250ml of coffee in the plunger, although if you are making multiple cups together then it gets a bit stronger.
    You will find instructions from various experts on how long to brew it, varying from 90secs to 5 minutes.
    Try them all out and then decide which is best for you.
    The grind can also make a big difference.
    Alan
  1. Rocky and French press
    By drovers-sunrise in forum Brewing Equipment - Manual Coffee Brewing Processes
    Last Post: 6th April 2013, 09:09 AM
  2. Le French Press grind?
    By tomas_szollosi in forum Brewing Equipment (non-machine specific)
    Last Post: 2nd April 2009, 08:49 AM
  3. French press
    By coastal_coffee in forum Brewing Equipment (non-machine specific)
    Last Post: 6th June 2007, 05:37 PM
