If you put your machine in the front seat of your car it might end up here..........mine had a leaky valve and I rushed it off for some help, back home now feeling much better, thankyou.
Originally posted by fishinglizard1972 link=1226910277/0#0 date=1226910275
If you put your machine in the front seat of your car it might end up here..........mine had a leaky valve and I rushed it off for some help, back home now feeling much better, thank you.
No seat belt and In addition any patient is required to be in the back, are they not; Unless under special circumstances.
Now looking at the Model of the vehicle and the distinctive pattern and label on the door and floor, as well as water on the LH panel...
