I find that I throw away a sizeable amount of coffee each time I prepare a couple of cups. How do others minimize the wastage? My Mini Mazzer tends to throw the grounds around when the portafilter is nearly filled due to a possible static buildup. Ive tried slowing down the clicks but that doesnt seem to make a difference.
Minimizing Espresso waste
Re: Minimizing Espresso waste
Originally posted by Cervelo link=1228338585/0#0 date=1228338585I find that I throw away a sizeable amount of coffee each time I prepare a couple of cups. How do others minimize the wastage? My Mini Mazzer tends to throw the grounds around when the portafilter is nearly filled due to a possible static buildup. Ive tried slowing down the clicks but that doesnt seem to make a difference.
Hi
How much wastage are we talking about here? I might lose up to a gram if Im only making one shot but if Im doing more, I will scrape the excess grounds back into the doser for the next shot. The grounds I dont use I store in a plastic tub and use for the priming shot after doing a detergent backflush.
As for dispensing the grounds, I tend to hold the portafilter handle to the left when thwacking the doser handle as the Mini tends to throw that way. You can try reducing how much is dispensed each thwack by tightening* the nut inside the doser to dose the minimum amount each thwack. Fill about 3/4 full then tap on the bench to settle then add mor. I also rotate the handle to try to distribute the grounds fairly evenly rather than in one pile. Others rattle the handle to achieve the same thing.
Something else you can try is the Weiss distribution technique which means cutting a yoghurt cup to fit inside the basket and low enough to fit under the doser.
* this is from memory so I hope someone corrects me if it is the other way around
I like your idea about using up the grounds. Ive simply been throwing them out and quite a bit since following the >35 second ground rule. I sweep out the mouth of the Mazzer prior to my next shot. I likely throw away a double or triple in grounds from the base of the mazzer and the clearing of the mouth every morning.
I havent had any wastage to use for my seasoning shots for a very long time now.
I measure my beans into the basket first then pour them into the grinder.
I get most, if not all, of what I put in, back out by clearing the chute with a paint brush after grinding and giving the grinder another pulse or two to throw the last of the grounds down the chute for one last brush.
If you dont want to measure the beans first, simply change your routine to sweep the mouth of the mazzer before dosing.
Youll need to put less beans in but will no doubt work that out as you go.
Im not sure if Im allowed to post links to threads on other coffee websites so please slap me if Ive been naughty
This is the remedy I stumbled across for my messy mazzer http://www.home-barista.com/forums/how-to-tame-messy-mazzer-doser-t6499.html
It works fantastic and I recently made one out of thin aluminium sheet. I had to modify the design slightly to make it fit.
Theres a whole thread on here somewhere with pics of deflectors that stop the coffee shooting to the left.
In your case gronk if what youve done doesnt hold firmly, you can make up something similar and secure it with those screws on the front of the grinder.
