I may be wrong but the boiler may be a 3lt boiler but it would only be a fraction of that which would be filled with water and the rest is headspace for steam, wont it? I think you can fill up the boiler but would have to disconnect some switch or other... (something to do with the level sensor).
Ive got a 1.5lt boiler and when I do the purge, I only get 300-400ml before nothing comes out of the hot water spout.
It is part of my maitenence routine
1) Polish the bling stainless steel, 2) empty out the 4 lt water resevour through the hot water tap via the boiler, 3) remove the resevour tank and wash it inside and out , 4) refit inside machine & fill with fresh filtered water
5) it regularly coinsides with my chemical backflushing times
