Has anyone tried using these or know if they are a viable option? mod edit- URL removed. I will need to install a softener of some type and these look to be simple to fit and supposedly last forever. Any comments or advice appreciated.
Water Softeners
Re: Water Softeners
Whoops, I inadvertantly directed this to a non sponser commercial site. I only wanted to clearly identify the product in question. This is the so called "MAIC" water softening system (MAgnetises, Ionises, Catalyzes). Anyone used one or can advise whether these are a viable option? It seems a bit questionable as the calcium is not removed, but instead "suspended" in the water by the process, so supposedly it will not calcify in the machine, but merely pass through the system. Any comments appreciated.
Re: Water Softeners
Hi
This is my personal opinion. Background: Science (PhD) and Process Engineering. Quoting from a few websites http://www.imexserve.it/water-softener-pr-28.html,
http://www.empiresteam.co.nz/products/other-products/water-softeners/
The MAIC technology works in 3 stages:
* MAGNETIZATION: The energy generated by the permanent magnets
causes molecular decomposition.
Personal opinion: CRAP
* IONIZATION: The magnets are positioned in alternate polarity to break
up the bicarbonate molecules, thus reducing them in shape and volume.
* CATALYZATION: The catalytic induction fixes this transformation and
keeps it more stable and durable even in presence of high temperatures
or high water hardness.
The effect of this process through the MAIC technology is that a new
crystal is formed, the Aragonite, which stays suspended in the water
and is exhausted by the simple water flow.
I dont have a phase diagram handy to look at to see the stability of the
aragonite form of CaCO3 compared to the calcite form at room temp and coffee boiler temp/pressure but I doubt the temp/pressure range will have any effect. The addition of salts such as sulphate, magnesium ions do have an effect on the crystal form of scale deposited in kettles (it can often be in the form of aragonite) but magnets have no effect.
My advice is to steer clear of products that make claims such as these.
Mike
